Hello everyone! I am doing my "RapidMiner Analyst Online Certification" test tomorrow. I would like to know the format of the exam, will it be multiple choice only? Essay? or work on a RapidMiner and upload it?
Thank you in advance.
There should be a sample exam somewhere on the RapidMiner Online University after you log in. Unless they changed something since last year, it'll be multiple choice.
the link above is broken here is the right one: https://certification.rapidminer.com/
it is 90 minutes mutiple choice. When you login to the remote proctor (link provided by RM EDU but current as of Nov 2017 is: http://rapidi.remoteproctor.com/) to access the certification you can select first to do a test. Then on the learning mangement system of RM EDU you can select the simple test exam. It has only 3 questions but it give you an impression on the look and feel. Good luck!
