com.rapidminer.operator.UserError: Database connection failed: connection MSSQL is unknown.
Hello!
I'm trying to run process from server and then there are an error "com.rapidminer.operator.UserError: Database connection failed: connection MSSQL is unknown. Please define the connection properly."
When i click run process locally it works.
How can i upload connection from studio? or how can i solve this problem.
Other quiestion
When trying to reload Database drivers there are error
Cannot reload database drivers, 'C:\Rapid\standalone\configuration\.RapidMiner\jdbc_properties.xml' not found.
1 - 4 of
41
hello @Ikalaus - you need to create database connections in Server if you want it to use them. Log into the web interface as admin and then go to Administration -> Database connections. Set everything up there (including testing) and you should be good to go.
Scott
