Hello Everyone,
I am currently trying to do a small exercise to get to know the contacts better in HyperMesh/OptiStruct. For this, I created a flat sheet as a ply laminate and a round metal block made from steel. Now, the flat sheet is supposed to be suspended in the middle by SPC and the rest of it shall "fall down" onto the metal block. I have set the GRAV card as required and the sheet is falling as expected... right through the metal block.
What I need next is contacts I believe, however I have not quite grasped how it works. I have created contactsurfs for the metal block surface and the laminate sheet and applied a Contact. However when I vary the parameters of the contact, sometimes it kind of works but most of the times it does most. More often than not, the flat sheet is falling through the metal block yet again, but not after sticking on the upper metal block side in weird ways.
I am also unsure whether to use FREEZE or SLIDE. I am tending to SLIDE because thats what the sheet is supposed to do, but it only ever worked kind of with a FREEZE.
I have uploaded the .HM-file. It would be fantastic, if someone could check in and tell me what I need to do differently to finally make it work! I am expecting that the laminate will lay onto the metal block on the upper part, but not fully enclose the metal block on the lower parts due to its stiffness. This has however never quite happened...
Any help would be great!
Best Regards,
Lennart
