It's showing " Java could not be launched. Probably there is not enough memory space. Please close all other applications and try again". But I have 8gb ram and nearly 1tb hard drive space. I don't why it's showing like that.
Did you close all your applications? Windows sucks up 2GB right off the bat and if you're running other stuff that could compete with RM but usually 8GB is plenty.
Potentially this might also have to do something with a mismatch between operating system and installed RapidMiner version. Are you using Windows? Is it the 32 bit or 64 bit version? And did you install the matching RapidMiner version for this?
Hope this helps,
Ingo
I have the same problem, even when I restart my PC and just run rapidminer 64 bit on Windows 10, have 16 GB RAM.
It worked fine just 10 days ago.
Did you perform an upgrade?
No, I don't. Everything is the same from 10 days ago (apart from updating Microsoft patch)
Here is the report I got after running through Bat filehttps://pastebin.com/TKKe6kv3
Hello @timematoom,
Thank you for inluding the pastebin of the full error - the key part that I noticed is EXCEPTION_ACCESS_VIOLATION (0xc0000005) - https://www.java.com/en/download/help/exception_access.xml
This error can arise if you are not running the launcher with full permissions - can you launch it by right clicking run as administrator?
hello,
I have worked with rapidminer for months but today I'm surprised by this error " Java could not be launched ".
this is the problem message
when I run rapidminerstudio.exe I got this error
RAPIDMINER_HOME environment variable is not set. Trying the directory 'C:\Program Files\RapidMiner\RapidMiner Studio'...Using local jre: C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\java.exe...Java Version: 1.8.0_141Launching RapidMiner Studio GUI now...Exception in thread "main" java.lang.Error: javax.xml.datatype.DatatypeConfigurationException: Provider for class javax.xml.datatype.DatatypeFactory cannot be found at javax.xml.bind.DatatypeConverterImpl.<clinit>(DatatypeConverterImpl.java:892) at javax.xml.bind.DatatypeConverter.initConverter(DatatypeConverter.java:140) at javax.xml.bind.DatatypeConverter.parseBase64Binary(DatatypeConverter.java:341) at com.rapidminer.license.verification.JarVerifier.verify(JarVerifier.java:130) at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:283)Caused by: javax.xml.datatype.DatatypeConfigurationException: Provider for class javax.xml.datatype.DatatypeFactory cannot be found at javax.xml.datatype.FactoryFinder.findServiceProvider(FactoryFinder.java:304) at javax.xml.datatype.FactoryFinder.find(FactoryFinder.java:268) at javax.xml.datatype.DatatypeFactory.newInstance(DatatypeFactory.java:145) at javax.xml.bind.DatatypeConverterImpl.<clinit>(DatatypeConverterImpl.java:890) ... 4 moreCaused by: java.util.ServiceConfigurationError: javax.xml.datatype.DatatypeFactory: Provider org.apache.xerces.jaxp.datatype.DatatypeFactoryImpl not found at java.util.ServiceLoader.fail(ServiceLoader.java:239) at java.util.ServiceLoader.access$300(ServiceLoader.java:185) at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:372) at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404) at java.util.ServiceLoader$1.next(ServiceLoader.java:480) at javax.xml.datatype.FactoryFinder$1.run(FactoryFinder.java:297) at java.security.AccessController.doPrivileged(Native Method) at javax.xml.datatype.FactoryFinder.findServiceProvider(FactoryFinder.java:292) ... 7 more
I have windows 8.1 RAM 8GO. what's the problem source and how can I solved it. yesterday I have updated the radoop extension. after the installation of the extension is finished I haven't rerun the application. could this be a source ??
thank you for your help.
