Cannot connect to Marketplace
heath_gordon
heath_gordon New Altair Community Member
Hello. I am running Ubuntu and I have installed both Rapidminer 7.4 and 7.5 but in neither case can I connect to the Marketplace. I suspect this has something to do with Java, I'm running 8, as it says is required when downloading. Any help would be great. Thanks.
Best Answer
  • balaji_sundaram
    balaji_sundaram New Altair Community Member
    Answer ✓
    Try performing the following steps
    Step1: Try updating the JAVA version
    Step2: Switch off the Anti Virus on your PC and try reopening the Rapidminer and the marketplace
  • heath_gordon
    Here is the output when I try to connect and I then hit 'get details':
    Exception: java.io.IOException
    Message: javax.xml.ws.WebServiceException: Failed to access the WSDL at: https://marketplace.rapidminer.com/UpdateServer/UpdateServiceService?wsdl. It failed with:
        sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target.
    Stack trace:
      com.rapidminer.deployment.update.client.MarketplaceUpdateManager.getService(MarketplaceUpdateManager.java:576)
      com.rapidminer.deployment.update.client.UpdateDialog$4.run(UpdateDialog.java:221)
      com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:550)
      java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
      java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
      java.lang.Thread.run(Thread.java:745)
    Cause
    Exception: javax.xml.ws.WebServiceException
    Message: Failed to access the WSDL at: https://marketplace.rapidminer.com/UpdateServer/UpdateServiceService?wsdl. It failed with:
    Stack trace:
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(RuntimeWSDLParser.java:250)
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:231)
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:194)
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:163)
      com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(WSServiceDelegate.java:348)
      com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:306)
      com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:215)
      com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:196)
      com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:192)
      com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(ProviderImpl.java:104)
      javax.xml.ws.Service.<init>(Service.java:77)
      com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:57)
      com.rapidminer.deployment.update.client.MarketplaceUpdateManager.getService(MarketplaceUpdateManager.java:572)
    Cause
    Exception: javax.net.ssl.SSLHandshakeException
    Message: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    Stack trace:
      sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
      sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
      sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302)
      sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296)
      sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1509)
      sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
      sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
      sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
      sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
      sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
      sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
      sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
      sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
      sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
      sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1513)
      sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:90)
      sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1433)
      sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1431)
      java.security.AccessController.doPrivileged(Native Method)
      java.security.AccessController.doPrivilegedWithCombiner(AccessController.java:782)
      sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1430)
      sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254)
      java.net.URL.openStream(URL.java:1045)
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(RuntimeWSDLParser.java:984)
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(RuntimeWSDLParser.java:385)
      com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:216)
    Cause
    Exception: sun.security.validator.ValidatorException
    Message: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    Stack trace:
      sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387)
      sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
      sun.security.validator.Validator.validate(Validator.java:260)
      sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
      sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
      sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
      sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1491)
    Cause
    Exception: sun.security.provider.certpath.SunCertPathBuilderException
    Message: unable to find valid certification path to requested target
    Stack trace:
      sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
      sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
      java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
      sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382)
  • Thomas_Ott
    Are you behind a proxy or firewall? That's usually the culprit.
  • heath_gordon
    Nope. I've tried to use it both at school and at home and it fails in both situations. I should point out that I'm the only one having this problem in my class, although I'm the only one running it on Linux.
  • Thomas_Ott
    Hmm. Not sure what it could be. If you need the extensions right away then I suggest you download the JAR files from the marketplace directly and save them to the /extensions folder whereever you installed RapidMiner. Then restart RapidMiner.
  • zeno_mas
    zeno_mas New Altair Community Member
    Having the same issue..
    Connection timed out: connect.
    Stack trace:
    com.rapidminer.deployment.update.client.MarketplaceUpdateManager.getService(MarketplaceUpdateManager.java:578)
    java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
    java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
    java.lang.Thread.run(Thread.java:748)
    Cause
    Stack trace:
    com.rapidminer.deployment.update.client.MarketplaceUpdateManager.getService(MarketplaceUpdateManager.java:574)
    Cause
    Exception: java.net.ConnectException
    Message: Connection timed out: connect
    Stack trace:
    java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
    java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
    java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
    java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
    java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
    java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
    java.net.Socket.connect(Socket.java:589)
    sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:673)
    sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:173)
    sun.net.NetworkClient.doConnect(NetworkClient.java:180)
    sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
    sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
    sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
    sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)
    sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
    sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
    sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1022)
    sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1020)
    sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1019)
    sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
    sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
    sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:91)
    sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1466)
    sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1464)
    sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1463)
  • sgenzer
    sgenzer
    hello @zeno_mas - I would follow @Thomas_Ott 's advice above.
    Scott
  • la_wane_05
    la_wane_05 New Altair Community Member
    I had the same problem and could not find the correct "extensions" folder because of the way installed the files.
    The following thread helped to install manually in correct path: https://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/Install-Extensions-Manually-for-RapidMiner-Studio/ta-p/31996
  • balaji_sundaram
    Answer ✓
