Hello everyone,
I have found a similar problem in the forum, but the solution there does not seem applicable.
I use Rapidminer Studio 7.4 on Win64.
When I click extensions -> Marketplace I get the following error message:
Exception: java.io.IOException
Message: javax.xml.ws.WebServiceException: Failed to access the WSDL at: https://marketplace.rapidminer.com/UpdateServer/UpdateServiceService?wsdl. It failed with:
sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target.
Stack trace:
com.rapidminer.deployment.update.client.MarketplaceUpdateManager.getService(MarketplaceUpdateManager.java:576)
com.rapidminer.deployment.update.client.UpdateDialog$4.run(UpdateDialog.java:221)
com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:550)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
java.lang.Thread.run(Thread.java:745)
Cause
Exception: javax.xml.ws.WebServiceException
Message: Failed to access the WSDL at: https://marketplace.rapidminer.com/UpdateServer/UpdateServiceService?wsdl. It failed with:
Stack trace:
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(RuntimeWSDLParser.java:250)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:231)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:194)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:163)
com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(WSServiceDelegate.java:348)
com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:306)
com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:215)
com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:196)
com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:192)
com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(ProviderImpl.java:104)
javax.xml.ws.Service.<init>(Service.java:77)
com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:57)
com.rapidminer.deployment.update.client.MarketplaceUpdateManager.getService(MarketplaceUpdateManager.java:572)
Cause
Exception: javax.net.ssl.SSLHandshakeException
Message: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Stack trace:
sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302)
sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296)
sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1497)
sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:212)
sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:563)
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1512)
sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:90)
sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1432)
sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1430)
java.security.AccessController.doPrivileged(Native Method)
java.security.AccessController.doPrivileged(AccessController.java:713)
sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1429)
sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254)
java.net.URL.openStream(URL.java:1038)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(RuntimeWSDLParser.java:984)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(RuntimeWSDLParser.java:385)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:216)
Cause
Exception: sun.security.validator.ValidatorException
Message: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Stack trace:
sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387)
sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
sun.security.validator.Validator.validate(Validator.java:260)
sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1479)
Cause
Exception: sun.security.provider.certpath.SunCertPathBuilderException
Message: unable to find valid certification path to requested target
Stack trace:
sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:145)
sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:131)
java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382)
At this workplace we have some proxy settings, but the local support says it may be a proxy authentication issue. I don't know. Any suggestions?
Thanks in advance
