I configured a Radoop connection to a HA Cloudera cluster and access to Hive and Impala works. But when I try to start a Spark Operator it fails when the Spark Application Master is started:
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=128m; support was removed in 8.0
17/04/24 10:52:57 INFO yarn.ApplicationMaster: Registered signal handlers for [TERM, HUP, INT]
Unknown/unsupported param List(--executor-memory, 58880m, --executor-cores, 40, --properties-file, /mnt/disk1/yarn/nm/usercache/datameer/appcache/application_1492760101213_0043/container_e12_1492760101213_0043_01_000001/__spark_conf__/__spark_conf__.properties)
Usage: org.apache.spark.deploy.yarn.ApplicationMaster [options]
Options:
--jar JAR_PATH Path to your application's JAR file
--class CLASS_NAME Name of your application's main class
--primary-py-file A main Python file
--primary-r-file A main R file
--py-files PY_FILES Comma-separated list of .zip, .egg, or .py files to
place on the PYTHONPATH for Python apps.
--args ARGS Arguments to be passed to your application's main class.
Multiple invocations are possible, each will be passed in order.
--properties-file FILE Path to a custom Spark properties file.
I created the connection with the exported client configuration from Cloudera manager:
Configuration
I also attached the XML configuration
