I cannot connect to my database through RapidMiner Studio. I have installed the driver for MySQL
User: "gcr84"
New Altair Community Member
Updated by Jocelyn
I am having trouble connecting my database to RapidMiner. After pressing the 'Add Data' button in RapidMiner studio (upper left corner),
I choose the 'Database' option. After successfully choosing the data location (as well as testing the connection, which is ok),
I choose the table entitled 'events' (containing 5 attributes), and use the SQL Query:
SELECT *
FROM `events`
Then storing the data in Local repository -> Data (I tried processes as well), naming the data 'saninudge', pressing 'finish', I get an error pop-up window with the following message:
'Cannot read data set contents. Failed to read the data. No database selected'.
At this point I browsed the web and discovered that the MySQL Driver must be installed and configured. So I followed the steps and made sure everything has correct values in the setup. Afterwards, again atempting to connect the database,
pressing the 'Add Data' button in RapidMiner studio (upper left corner), I choose the 'Database' option again. Again testing the connection to the correct database ('Saninudge') checks out, but then after pressing the 'Next' button the window is empty and no tables are visible.
So at this point I am really stuck and could use some advice on how to successfully connect RapidMiner Studio to my database. Any ideas why the tables suddenly appears empty after installing the MySQL Driver? ANy help is much appreciated.
