Hi
I need to connect to Splunk with RapidMiner. So I installed Splunk extension and tried to connect, but it's fail.
It's the message when I clicked test button.
let me know your good answers
Thanks
I'm not the Splunk exper here, maybe @Marco_Boeck can chime in.
我这边出现同样问题,现已解决。
1. 先解决协议不匹配(题主情况)
解决办法:屏蔽掉java 8默认关闭的sslv3
找到java.security,一般在安装目录jre/lib/security/java.security中,找到
这里默认disable掉sslv3,但是rapidminer ssl版本比较低,所以协议不对。注释掉这行就可以解决。
2. 解决协议匹配不对问题之后,我这边出现shadehand failture,查splunk log中发现协议版本不对
解决办法:
找到splunk sever配置(我这边目录是:/opt/splunk/etc/system/local ),打开server.conf,在[sslConfig] 中加入以下配置内容:
enableSplunkdSSL = truesslVersions = *,-ssl2 sslVersionsForClient = *,-ssl2 cipherSuite = TLSv1+HIGH:TLSv1.2+HIGH:@STRENGTH
3. 重启splunk应用服务,rapidminer,重新链接就可以链接成功了。
Splunk Extension version 8.2.0 was released today and should fix the issue.
Marco
