Hello everyone,
I am trying to run the following cluster algorithms on an exampleset, that I generated beforehand from different JSON files.
What I would like to do, is to buld clustrs of the example set and measure the quality of each algorithm.
I am facing 2 basic problems.
1. When running the process with just the centroid algorithms, the process finishes successfully, but it won't produce any clusters. Or at least I can not see them in the results.
2. When running the process as in the attached .xml, the process stops, as the cluster algorithms do not produce any output.
Can anyone look at my process and give me any suggestions?
Thank you very much!!
<operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.4.000" expanded="true" height="68" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="example list 1-300"/>
<operator activated="false" class="sample_kennard_stone" compatibility="7.4.000" expanded="true" height="82" name="Sample (Kennard-Stone)" width="90" x="246" y="340">
<parameter key="sample_size" value="600"/>
<operator activated="true" class="replace_missing_values" compatibility="7.4.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="179" y="34">
<list key="columns"/>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="103" name="Multiply (2)" width="90" x="380" y="30"/>
<operator activated="true" class="loop_parameters" compatibility="7.4.000" expanded="true" height="145" name="Loop Parameters" width="90" x="648" y="289">
<list key="parameters">
<parameter key="Select Subprocess (2).select_which" value="[1;3;3;linear]"/>
</list>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="103" name="Multiply (3)" width="90" x="45" y="136"/>
<operator activated="true" class="select_subprocess" compatibility="7.4.000" expanded="true" height="103" name="Select Subprocess (2)" width="90" x="246" y="34">
<operator activated="true" class="dbscan" compatibility="7.4.000" expanded="true" height="82" name="Clustering" width="90" x="112" y="34"/>
<operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="124" name="Subprocess (3)" width="90" x="112" y="289">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (8)" width="90" x="179" y="34"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance" width="90" x="447" y="34"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (2)" width="90" x="447" y="136">
<parameter key="measure" value="GiniCoefficient"/>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (9)" width="90" x="179" y="289"/>
<operator activated="false" class="cluster_distance_performance" compatibility="7.4.000" expanded="true" height="103" name="Performance (3)" width="90" x="447" y="289"/>
<operator activated="true" class="data_to_similarity" compatibility="7.4.000" expanded="true" height="82" name="Data to Similarity" width="90" x="179" y="442"/>
<operator activated="true" class="cluster_density_performance" compatibility="7.4.000" expanded="true" height="124" name="Performance (4)" width="90" x="447" y="442"/>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log" width="90" x="782" y="34">
<list key="log">
<parameter key="Avg_within_distance" value="operator.Performance (3).value.avg_within_distance"/>
<parameter key="Item_Distribution" value="operator.Performance (4).value.clusterdensity"/>
<parameter key="Gini" value="operator.Performance (2).value.item_distribution"/>
<parameter key="Cluster_Density" value="operator.Performance.value.item_distribution"/>
<parameter key="K" value="operator.Loop Parameters.value.iteration"/>
<parameter key="Davies" value="operator.Performance (3).value.DaviesBouldin"/>
</list>
<connect from_port="in 1" to_op="Multiply (8)" to_port="input"/>
<connect from_port="in 2" to_op="Multiply (9)" to_port="input"/>
<connect from_op="Multiply (8)" from_port="output 1" to_op="Performance" to_port="cluster model"/>
<connect from_op="Multiply (8)" from_port="output 2" to_op="Performance (4)" to_port="cluster model"/>
<connect from_op="Performance" from_port="cluster model" to_op="Performance (2)" to_port="cluster model"/>
<connect from_op="Multiply (9)" from_port="output 1" to_op="Performance (4)" to_port="example set"/>
<connect from_op="Multiply (9)" from_port="output 2" to_op="Data to Similarity" to_port="example set"/>
<connect from_op="Data to Similarity" from_port="similarity" to_op="Performance (4)" to_port="distance measure"/>
<connect from_op="Log" from_port="through 1" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="source_in 3" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
<portSpacing port="sink_out 4" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_op="Subprocess (3)" to_port="in 1"/>
<connect from_op="Clustering" from_port="clustered set" to_op="Subprocess (3)" to_port="in 2"/>
<connect from_op="Subprocess (3)" from_port="out 2" to_port="output 1"/>
<connect from_op="Subprocess (3)" from_port="out 3" to_port="output 2"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<operator activated="true" class="agglomerative_clustering" compatibility="7.4.000" expanded="true" height="82" name="Clustering (2)" width="90" x="112" y="34"/>
<operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="124" name="Subprocess (4)" width="90" x="112" y="289">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="82" name="Multiply (10)" width="90" x="179" y="34"/>
<operator activated="false" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (5)" width="90" x="447" y="34"/>
<operator activated="false" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (6)" width="90" x="447" y="136">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="103" name="Multiply (11)" width="90" x="179" y="289"/>
<operator activated="false" class="cluster_distance_performance" compatibility="7.4.000" expanded="true" height="103" name="Performance (7)" width="90" x="447" y="289"/>
<operator activated="true" class="data_to_similarity" compatibility="7.4.000" expanded="true" height="82" name="Data to Similarity (3)" width="90" x="179" y="442"/>
<operator activated="false" class="cluster_density_performance" compatibility="7.4.000" expanded="true" height="124" name="Performance (8)" width="90" x="447" y="442"/>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log (2)" width="90" x="782" y="34">
<list key="log">
</list>
<connect from_port="in 1" to_op="Multiply (10)" to_port="input"/>
<connect from_port="in 2" to_op="Multiply (11)" to_port="input"/>
<connect from_op="Multiply (11)" from_port="output 2" to_op="Data to Similarity (3)" to_port="example set"/>
<connect from_op="Log (2)" from_port="through 1" to_port="out 1"/>
</process>
<connect from_port="input 1" to_op="Clustering (2)" to_port="example set"/>
<connect from_op="Clustering (2)" from_port="cluster model" to_op="Subprocess (4)" to_port="in 1"/>
<connect from_op="Clustering (2)" from_port="example set" to_op="Subprocess (4)" to_port="in 2"/>
<connect from_op="Subprocess (4)" from_port="out 2" to_port="output 1"/>
<connect from_op="Subprocess (4)" from_port="out 3" to_port="output 2"/>
</process>
<operator activated="true" class="support_vector_clustering" compatibility="7.4.000" expanded="true" height="82" name="Clustering (3)" width="90" x="112" y="34"/>
<operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="124" name="Subprocess (5)" width="90" x="112" y="289">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (12)" width="90" x="179" y="34"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (9)" width="90" x="447" y="34"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (10)" width="90" x="447" y="136">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (13)" width="90" x="179" y="289"/>
<operator activated="false" class="cluster_distance_performance" compatibility="7.4.000" expanded="true" height="103" name="Performance (11)" width="90" x="447" y="289"/>
<operator activated="true" class="data_to_similarity" compatibility="7.4.000" expanded="true" height="82" name="Data to Similarity (4)" width="90" x="179" y="442"/>
<operator activated="true" class="cluster_density_performance" compatibility="7.4.000" expanded="true" height="124" name="Performance (12)" width="90" x="447" y="442"/>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log (3)" width="90" x="782" y="34">
<list key="log">
</list>
<connect from_port="in 1" to_op="Multiply (12)" to_port="input"/>
<connect from_port="in 2" to_op="Multiply (13)" to_port="input"/>
<connect from_op="Multiply (12)" from_port="output 1" to_op="Performance (9)" to_port="cluster model"/>
<connect from_op="Multiply (12)" from_port="output 3" to_op="Performance (12)" to_port="cluster model"/>
<connect from_op="Performance (9)" from_port="cluster model" to_op="Performance (10)" to_port="cluster model"/>
<connect from_op="Multiply (13)" from_port="output 2" to_op="Performance (12)" to_port="example set"/>
<connect from_op="Multiply (13)" from_port="output 3" to_op="Data to Similarity (4)" to_port="example set"/>
<connect from_op="Data to Similarity (4)" from_port="similarity" to_op="Performance (12)" to_port="distance measure"/>
<connect from_op="Log (3)" from_port="through 1" to_port="out 1"/>
</process>
<connect from_port="input 1" to_op="Clustering (3)" to_port="example set"/>
<connect from_op="Clustering (3)" from_port="cluster model" to_op="Subprocess (5)" to_port="in 1"/>
<connect from_op="Clustering (3)" from_port="clustered set" to_op="Subprocess (5)" to_port="in 2"/>
<connect from_op="Subprocess (5)" from_port="out 2" to_port="output 1"/>
<connect from_op="Subprocess (5)" from_port="out 3" to_port="output 2"/>
</process>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (4)" width="90" x="313" y="289"/>
<operator activated="true" class="extract_prototypes" compatibility="7.4.000" expanded="true" height="82" name="Extract Cluster Prototypes" width="90" x="514" y="391"/>
<operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="103" name="Subprocess (6)" width="90" x="447" y="136">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (14)" width="90" x="179" y="34"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (13)" width="90" x="447" y="34"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (14)" width="90" x="447" y="136">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (15)" width="90" x="179" y="289"/>
<operator activated="true" class="cluster_distance_performance" compatibility="7.4.000" expanded="true" height="103" name="Performance (15)" width="90" x="447" y="289"/>
<operator activated="true" class="data_to_similarity" compatibility="7.4.000" expanded="true" height="82" name="Data to Similarity (5)" width="90" x="179" y="442"/>
<operator activated="true" class="cluster_density_performance" compatibility="7.4.000" expanded="true" height="124" name="Performance (16)" width="90" x="447" y="442"/>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log (4)" width="90" x="782" y="34">
<list key="log">
</list>
<connect from_port="in 1" to_op="Multiply (14)" to_port="input"/>
<connect from_port="in 2" to_op="Multiply (15)" to_port="input"/>
<connect from_op="Multiply (14)" from_port="output 1" to_op="Performance (13)" to_port="cluster model"/>
<connect from_op="Multiply (14)" from_port="output 2" to_op="Performance (15)" to_port="cluster model"/>
<connect from_op="Multiply (14)" from_port="output 3" to_op="Performance (16)" to_port="cluster model"/>
<connect from_op="Performance (13)" from_port="cluster model" to_op="Performance (14)" to_port="cluster model"/>
<connect from_op="Multiply (15)" from_port="output 1" to_op="Performance (15)" to_port="example set"/>
<connect from_op="Multiply (15)" from_port="output 2" to_op="Performance (16)" to_port="example set"/>
<connect from_op="Multiply (15)" from_port="output 3" to_op="Data to Similarity (5)" to_port="example set"/>
<connect from_op="Data to Similarity (5)" from_port="similarity" to_op="Performance (16)" to_port="distance measure"/>
<connect from_op="Log (4)" from_port="through 1" to_port="out 1"/>
</process>
<operator activated="true" class="log_to_data" compatibility="7.4.000" expanded="true" height="103" name="Log to Data" width="90" x="648" y="136"/>
<operator activated="true" class="guess_types" compatibility="7.4.000" expanded="true" height="82" name="Guess Types" width="90" x="849" y="136"/>
<connect from_port="input 1" to_op="Multiply (3)" to_port="input"/>
<connect from_op="Multiply (3)" from_port="output 1" to_op="Select Subprocess (2)" to_port="input 1"/>
<connect from_op="Multiply (3)" from_port="output 2" to_op="Subprocess (6)" to_port="in 2"/>
<connect from_op="Select Subprocess (2)" from_port="output 1" to_op="Multiply (4)" to_port="input"/>
<connect from_op="Select Subprocess (2)" from_port="output 2" to_port="result 2"/>
<connect from_op="Multiply (4)" from_port="output 1" to_op="Subprocess (6)" to_port="in 1"/>
<connect from_op="Multiply (4)" from_port="output 2" to_port="result 1"/>
<connect from_op="Multiply (4)" from_port="output 3" to_op="Extract Cluster Prototypes" to_port="model"/>
<connect from_op="Extract Cluster Prototypes" from_port="example set" to_port="result 4"/>
<connect from_op="Subprocess (6)" from_port="out 1" to_op="Log to Data" to_port="through 1"/>
<connect from_op="Log to Data" from_port="exampleSet" to_op="Guess Types" to_port="example set input"/>
<connect from_op="Guess Types" from_port="example set output" to_port="result 3"/>
<portSpacing port="sink_performance" spacing="0"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
<operator activated="true" class="loop_parameters" compatibility="7.4.000" expanded="true" height="145" name="Centroid Algo" width="90" x="648" y="30">
<parameter key="Select Subprocess.select_which" value="[1;3;3;linear]"/>
</list>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="94" name="Multiply" width="90" x="45" y="120"/>
<operator activated="true" class="select_subprocess" compatibility="7.4.000" expanded="true" height="103" name="Select Subprocess" width="90" x="246" y="30">
<parameter key="select_which" value="3"/>
<operator activated="true" class="k_means" compatibility="7.4.000" expanded="true" height="82" name="k-Means" width="90" x="45" y="30">
<parameter key="k" value="9"/>
<connect from_port="input 1" to_op="k-Means" to_port="example set"/>
<connect from_op="k-Means" from_port="cluster model" to_port="output 1"/>
<connect from_op="k-Means" from_port="clustered set" to_port="output 2"/>
</process>
<operator activated="true" class="x_means" compatibility="7.4.000" expanded="true" height="82" name="X-Means" width="90" x="45" y="30"/>
<connect from_port="input 1" to_op="X-Means" to_port="example set"/>
<connect from_op="X-Means" from_port="cluster model" to_port="output 1"/>
<connect from_op="X-Means" from_port="clustered set" to_port="output 2"/>
</process>
<operator activated="true" class="k_medoids" compatibility="7.4.000" expanded="true" height="82" name="K Medoid" width="90" x="45" y="30">
<connect from_port="input 1" to_op="K Medoid" to_port="example set"/>
<connect from_op="K Medoid" from_port="cluster model" to_port="output 1"/>
<connect from_op="K Medoid" from_port="clustered set" to_port="output 2"/>
</process>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="103" name="Multiply (7)" width="90" x="313" y="340"/>
<operator activated="true" class="extract_prototypes" compatibility="7.4.000" expanded="true" height="82" name="Extract Cluster Prototypes (2)" width="90" x="581" y="289"/>
<operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="103" name="Subprocess (2)" width="90" x="447" y="120">
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (5)" width="90" x="246" y="30"/>
<operator activated="true" class="multiply" compatibility="7.4.000" expanded="true" height="124" name="Multiply (6)" width="90" x="246" y="210"/>
<operator activated="true" class="data_to_similarity" compatibility="7.4.000" expanded="true" height="82" name="Data to Similarity (2)" width="90" x="246" y="345"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Distribution SoS (2)" width="90" x="447" y="30"/>
<operator activated="true" class="item_distribution_performance" compatibility="7.4.000" expanded="true" height="82" name="Distribution Gini (2)" width="90" x="447" y="120">
<operator activated="true" class="cluster_distance_performance" compatibility="7.4.000" expanded="true" height="103" name="Distance (2)" width="90" x="447" y="210">
<parameter key="normalize" value="true"/>
<operator activated="false" class="cluster_density_performance" compatibility="7.4.000" expanded="true" height="124" name="Density (2)" width="90" x="447" y="345"/>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log: Internal" width="90" x="715" y="30">
<list key="log">
<parameter key="avgWithinDistance" value="operator.Distance (2).value.avg_within_distance"/>
<parameter key="itemDistribution" value="operator.Density (2).value.clusterdensity"/>
<parameter key="Gini" value="operator.Distribution Gini (2).value.item_distribution"/>
<parameter key="clusterDensity" value="operator.Distribution SoS (2).value.item_distribution"/>
<parameter key="K" value="operator.Centroid Algo.value.iteration"/>
<parameter key="Davis" value="operator.Distance (2).value.DaviesBouldin"/>
</list>
<connect from_port="in 1" to_op="Multiply (5)" to_port="input"/>
<connect from_port="in 2" to_op="Multiply (6)" to_port="input"/>
<connect from_op="Multiply (5)" from_port="output 1" to_op="Distribution SoS (2)" to_port="cluster model"/>
<connect from_op="Multiply (5)" from_port="output 2" to_op="Distance (2)" to_port="cluster model"/>
<connect from_op="Multiply (6)" from_port="output 1" to_op="Distance (2)" to_port="example set"/>
<connect from_op="Multiply (6)" from_port="output 2" to_op="Data to Similarity (2)" to_port="example set"/>
<connect from_op="Distribution SoS (2)" from_port="cluster model" to_op="Distribution Gini (2)" to_port="cluster model"/>
<connect from_op="Log: Internal" from_port="through 1" to_port="out 1"/>
</process>
<operator activated="true" class="log_to_data" compatibility="7.4.000" expanded="true" height="94" name="Internal validity measures" width="90" x="648" y="120">
<parameter key="log_name" value="Log: Internal"/>
<operator activated="true" class="guess_types" compatibility="7.1.001" expanded="true" height="76" name="Internal" width="90" x="782" y="120"/>
<connect from_port="input 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Select Subprocess" to_port="input 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="Subprocess (2)" to_port="in 2"/>
<connect from_op="Select Subprocess" from_port="output 1" to_op="Multiply (7)" to_port="input"/>
<connect from_op="Select Subprocess" from_port="output 2" to_port="result 2"/>
<connect from_op="Multiply (7)" from_port="output 1" to_op="Subprocess (2)" to_port="in 1"/>
<connect from_op="Multiply (7)" from_port="output 2" to_op="Extract Cluster Prototypes (2)" to_port="model"/>
<connect from_op="Extract Cluster Prototypes (2)" from_port="example set" to_port="result 4"/>
<connect from_op="Subprocess (2)" from_port="out 1" to_op="Internal validity measures" to_port="through 1"/>
<connect from_op="Internal validity measures" from_port="exampleSet" to_op="Internal" to_port="example set input"/>
<connect from_op="Internal" from_port="example set output" to_port="result 1"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Centroid Algo" to_port="input 1"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Loop Parameters" to_port="input 1"/>
<connect from_op="Loop Parameters" from_port="result 2" to_port="result 4"/>
<connect from_op="Loop Parameters" from_port="result 3" to_port="result 5"/>
<connect from_op="Loop Parameters" from_port="result 4" to_port="result 6"/>
<connect from_op="Centroid Algo" from_port="result 2" to_port="result 1"/>
<connect from_op="Centroid Algo" from_port="result 3" to_port="result 2"/>
<connect from_op="Centroid Algo" from_port="result 4" to_port="result 3"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
</process>
</process>
