I am simulating an electrical motor that uses M800-65A sheets. I am using the parametric distribution option in the scenario so the computation time is reduced.
I want to obtain the iron losses from predefined sheet models of FLUX. However, I do not know how to define a sensor for this result.
The lack of a sensor increases the processing time considerably, because the computation of the iron losses would also be distributed if I had a sensor defined, whereas now, I have to wait for quite a long time after the simulation has finished in order to obtain those results.
Any idea whether this is possible in Flux? I am currently using version 2020.1.
Best regards,
Imanol
