is a SVM invariant to Skewness and Kurtosis?
Fred12
Fred12 New Altair Community Member
I have data that is highly positively skewed, and I want to train a SVM (LibSVM) Classifier on the data with 3 classes... my question is, does skewness and/or curtosis affect performance of a SVM classifier? or is it invariant to those statistic measurements? or should I rather use a log transform for e.g skewed columns?
and which other classifiers are invariant of statistical measures, and which ones does affect them?
Welcome!
  • MartinLiebig
    MartinLiebig
    Fred,
    help me to get the connection. Kurtosis and Skeweness are univariate measures of a distribution. These do not depend on the label class. They have not that much todo with how a SVM works.
    The interesting part is to do a scatter plot between label and observerd attribute(s). The non-linearity here is the intersting thing to catch.
    ~Martin
  • Fred12
    well what I mean is, in linear Models like Generalized Linear Model, I think the distribution plays a role like skewness etc. therefore its useful at least with my dataset if I apply a log transformation on skew columns... I got 10%+ better performance after doing that.. outliers also play an important role I think,
    I just wanted to know if the same also applies to SVM, I tried with my dataset, both normal and log transformed, and somehow I got about 1- 1.5% better performance on my log-transformed dataset... how can that be?
  • MartinLiebig
    MartinLiebig
    Mh,
    it's overall a interesting question for a regression problem. The problem of GLMs comes from the underlying distribution assumption. By minimizing least squares you implicitly assume a normal distribution. Distributions with high skewness/kurtosis violate this assumption and are thus not performing well.
    For SVM-Regression i am not 100% sure if there is such an assumption in the Loss measure. I think it uses absolute loss with the Epsilon to ignore errors below this. Maybe @IngoRM or @RalfKlinkenberg can help, they got some more theoretical experience with SVMs.
    In any way, your increase in performance is explainable to me from a total different point of view. If you apply a log on all attributes, your kernel function gets different. That makes a obvious difference.
    Best,
    Martin
  • Fred12
    ok thanks, but what do you mean by my kernel function gets different? In what matter is it different?
  • MartinLiebig
    MartinLiebig
    Hey,
    if you look for example at the rbf kernel (https://en.wikipedia.org/wiki/Radial_basis_function_kernel ) you would simply replace x and x' with log(x) and log(x'). Thats simply different. Not necessarly good or bad, but different.
    ~Martin
Welcome!
Welcome!
