Hello together,
I use rapidminer to create ROC-curve (with "Compare ROCs") and now I want to edit the output. My question is, is it possible to edit this graphic in rapidminer or can I export the ROC-curve in excel?
thanks for help
Tobias
You can use the file menu and then select "print/export image" to get the actual image out of RapidMiner, but not to edit it. I am not familiar with a way to get the underlying numerical data into a file to output (such as Excel or csv). I would love to see that capability added, though, so you should put this in the "Product Ideas" forum if it turns out it is not possible.
