We have done analysis on interference fit with the objective to find out the slip or relative motion between parts under interference fit when subjected to torque . But could not conclude from the results analysed.
would like to interpret the results at what torque the fit will fail or slip?
First step interference is cleared and the first step is given as an input to the second step torque loading using CNTNLSUB
Radial Interference value - 0.014 mm ;Length of interference = 120 mm ; Torque applied = 6000 Nm ; Friction coefficient = 0.2
Two iterations have already been done and results file available with contact forces in h3d format
1) Torque - 500 Nm
2) Torque - 6000 Nm ( As per previous discussion , GPFORCE in opti format )
It would be helpful, if you could suggest what parameter in result file should be monitored to identify the shaft loosen from cylinder.
