when i am using the Performance Node for Classification i get an error which indicates an Out Of Memory Problem.
I optimized the Hive/Yarn/Tez settings as suggested in:
https://community.hortonworks.com/articles/14309/demystify-tez-tuning-step-by-step.html
and
https://docs.hortonworks.com/HDPDocuments/HDP2/HDP-2.3.4/bk_installing_manually_book/content/determine-hdp-memory-config.html
If i run the stream without the performance node, just the random forest model and some data preperation everything works fine.
The Error shown in Rapidminer is this one: (The same occurs in the hive log)
Exception: eu.radoop.exception.NoStackTraceOperatorException
Message: ERROR : Status: Failed Message: Error while processing statement: FAILED: Execution Error, return code 2 from org.apache.hadoop.hive.ql.exec.tez.TezTask. Vertex failed, vertexName=Map 1, vertexId=vertex_1481614577214_0004_1_00, diagnostics=[Task failed, taskId=t...
Stack trace:
Cause
Exception: java.sql.SQLException
Message: Error while processing statement: FAILED: Execution Error, return code 2 from org.apache.hadoop.hive.ql.exec.tez.TezTask. Vertex failed, vertexName=Map 1, vertexId=vertex_1481614577214_0004_1_00, diagnostics=[Task failed, taskId=task_1481614577214_0004_1_00_000000, diagnostics=[TaskAttempt 0 failed, info=[Error: Failure while running task:java.lang.RuntimeException: java.lang.OutOfMemoryError: Java heap space
at org.apache.hadoop.hive.ql.exec.tez.TezProcessor.initializeAndRunProcessor(TezProcessor.java:159)
at org.apache.hadoop.hive.ql.exec.tez.TezProcessor.run(TezProcessor.java:139)
at org.apache.tez.runtime.LogicalIOProcessorRuntimeTask.run(LogicalIOProcessorRuntimeTask.java:344)
at org.apache.tez.runtime.task.TezTaskRunner$TaskRunnerCallable$1.run(TezTaskRunner.java:181)
at org.apache.tez.runtime.task.TezTaskRunner$TaskRunnerCallable$1.run(TezTaskRunner.java:172)
at java.security.AccessController.doPrivileged(Native Method)
at javax.security.auth.Subject.doAs(Subject.java:422)
at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1657)
at org.apache.tez.runtime.task.TezTaskRunner$TaskRunnerCallable.callInternal(TezTaskRunner.java:172)
at org.apache.tez.runtime.task.TezTaskRunner$TaskRunnerCallable.callInternal(TezTaskRunner.java:168)
at org.apache.tez.common.CallableWithNdc.call(CallableWithNdc.java:36)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.OutOfMemoryError: Java heap space
at java.nio.HeapByteBuffer.<init>(HeapByteBuffer.java:57)
at java.nio.ByteBuffer.allocate(ByteBuffer.java:335)
at org.apache.tez.runtime.library.common.sort.impl.PipelinedSorter.<init>(PipelinedSorter.java:172)
at org.apache.tez.runtime.library.common.sort.impl.PipelinedSorter.<init>(PipelinedSorter.java:116)
at org.apache.tez.runtime.library.output.OrderedPartitionedKVOutput.start(OrderedPartitionedKVOutput.java:142)
at org.apache.hadoop.hive.ql.exec.tez.MapRecordProcessor.init(MapRecordProcessor.java:142)
at org.apache.hadoop.hive.ql.exec.tez.TezProcessor.initializeAndRunProcessor(TezProcessor.java:149)
... 14 more
], TaskAttempt 1 failed, info=[Error: Failure while running task:java.lang.RuntimeException: java.lang.OutOfMemoryError: Java heap space
... 14 more
], TaskAttempt 2 failed, info=[Error: Failure while running task:java.lang.RuntimeException: java.lang.OutOfMemoryError: Java heap space
... 14 more
], TaskAttempt 3 failed, info=[Error: Failure while running task:java.lang.RuntimeException: java.lang.OutOfMemoryError: Java heap space
... 14 more
]], Vertex did not succeed due to OWN_TASK_FAILURE, failedTasks:1 killedTasks:0, Vertex vertex_1481614577214_0004_1_00 [Map 1] killed/failed due to:OWN_TASK_FAILURE]Vertex killed, vertexName=Reducer 2, vertexId=vertex_1481614577214_0004_1_01, diagnostics=[Vertex received Kill while in RUNNING state., Vertex did not succeed due to OTHER_VERTEX_FAILURE, failedTasks:0 killedTasks:1, Vertex vertex_1481614577214_0004_1_01 [Reducer 2] killed/failed due to:OTHER_VERTEX_FAILURE]DAG did not succeed due to VERTEX_FAILURE. failedVertices:1 killedVertices:1
Stack trace:
org.apache.hive.jdbc.HiveStatement.execute(HiveStatement.java:296)
org.apache.hive.jdbc.HiveStatement.executeQuery(HiveStatement.java:392)
eu.radoop.datahandler.hive.HiveHandler.runScriptsOrQueriesKillableAction(HiveHandler.java:1393)
eu.radoop.datahandler.hive.HiveHandler.runScriptsOrQueriesKillable(HiveHandler.java:1204)
eu.radoop.datahandler.hive.HiveHandler.runQueriesKillable(HiveHandler.java:1179)
eu.radoop.datahandler.hive.HiveHandler.runQueryKillable(HiveHandler.java:1096)
eu.radoop.RadoopTools.calculateClassificationMatrix(RadoopTools.java:897)
eu.radoop.modeling.performance.HiveMultiClassificationPerformance.create(HiveMultiClassificationPerformance.java:63)
eu.radoop.modeling.performance.AbstractPerformanceEvaluator.evaluate(AbstractPerformanceEvaluator.java:497)
eu.radoop.modeling.performance.AbstractPerformanceEvaluator.evaluate(AbstractPerformanceEvaluator.java:406)
eu.radoop.modeling.performance.AbstractPerformanceEvaluator.doWork(AbstractPerformanceEvaluator.java:390)
com.rapidminer.operator.Operator.execute(Operator.java:1005)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:812)
com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:807)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
eu.radoop.operator.meta.RadoopValidationChain.executeEvaluator(RadoopValidationChain.java:207)
eu.radoop.operator.meta.RadoopValidationChain.evaluate(RadoopValidationChain.java:351)
eu.radoop.operator.meta.SplitValidationChain.estimatePerformance(SplitValidationChain.java:66)
eu.radoop.operator.meta.RadoopValidationChain.doWork(RadoopValidationChain.java:301)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428)
eu.radoop.RadoopNest.doWork(RadoopNest.java:643)
com.rapidminer.operator.meta.ParameterIteratingOperatorChain.executeSubprocess(ParameterIteratingOperatorChain.java:262)
com.rapidminer.operator.meta.ParameterIteratingOperatorChain.getPerformanceVector(ParameterIteratingOperatorChain.java:305)
com.rapidminer.operator.meta.ParameterIteration.evaluateParameterSet(ParameterIteration.java:230)
com.rapidminer.operator.meta.ParameterIteration.doWork(ParameterIteration.java:189)
com.rapidminer.Process.run(Process.java:1205)
com.rapidminer.Process.run(Process.java:1101)
com.rapidminer.Process.run(Process.java:1054)
com.rapidminer.Process.run(Process.java:1049)
com.rapidminer.Process.run(Process.java:1039)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
