 I am trying to use OptiStruct to analysis a structure containing 3 layer gaskets. For the convenience of subsequent optimization, I want the result of gasket thickness-direction pressure contains only 1 gasket. How can I edit the output setting to achieve this?
 I found that there are many output options in the subcase card, but I don't know which one controls the output of the gasket thickness-direction pressure.
 Thank you
