web service error "The script could not be parsed"
I have a RM process that runs well on local, but the web service has error:
de.rapidanalytics.ejb.service.ServiceDataSourceException Error executing process /home/RM/0_main_recommender for service 0_main_recommender: The script could not be parsed.
Couldn't find similar error online. Could somebody help please? Thanks!
RM in XML:
<process version="6.4.000">
<context>
<input/>
<output/>
<macros>
<macro>
<key>TABLE_IN_KNOWN</key>
<value>-1</value>
</macro>
<macro>
<key>TABLE_IN</key>
<value>-1</value>
</macro>
<macro>
<key>PREDICTOR</key>
<value>-1</value>
</macro>
<macro>
<key>LABEL</key>
<value>-1</value>
</macro>
<macro>
<key>METRIC</key>
<value>-1</value>
</macro>
<macro>
<key>GROUP</key>
<value>-1</value>
</macro>
<macro>
<key>METADATA</key>
<value>-1</value>
</macro>
<macro>
<key>TABLE_OUT</key>
<value>-1</value>
</macro>
</macros>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="r_scripting:execute_r" compatibility="6.4.000" expanded="true" height="60" name="Execute R" width="90" x="45" y="30">
<parameter key="script" value="library(RODBC) library(readr) library(dplyr) # get metadata from different sources #### parse_metadata = function(table_in_known, table_in, col_predictor, col_label, col_metric, col_group, metadata, table_out){ if(table_in_known != -1) { # read metadata from database ch = odbcConnect('AnalyticsEngine') sql0 = paste0(" SELECT * FROM [dbo].[aap_data_attribute_metadata] WHERE [table] = '", table_in_known, "'") sql0 = paste0(' SELECT * FROM [dbo].[aap_data_attribute_metadata]') cat(sql0, '\n\n') metadata_fixed = sqlQuery(ch, sql0) table_in = table_in_known } else { if (metadata != -1){ } else{ # what format of metadata? XML? metadata_fixed = data.frame(metadata) } # save it to database } if(table_out == -1){ table_out = paste(table_in, format(Sys.time(), '%Y_%m_%d_%H_%M_%S'), sep = '_') } list(table_in, metadata_fixed, table_out) } decide_scenario = function(metadata){ if ( ! 'label' %in% metadata$role){ # unsupervised scenario = c('outlier', 'clustering') } else if ( sum(metadata$role == 'label') > 1 ){ stop('more than one label not allowed') } else { # supervised if (metadata[metadata$role == 'label', 'datatype'] %in% c('numeric', 'int')) { scenario = 'regression' # if(metadata[metadata$role == 'label', 'datatype'] == 'int' & dat$){ # # warning('are you sure the label is numeric, rather than classes?') # } } else if (metadata[metadata$role == 'label', 'datatype'] %in% c('character', 'factor')) { scenario = 'classification' } } if('datetime' %in% metadata$role){ scenario = append(scenario, c('ts', 'aggregation')) } scenario = append(scenario, 'feature_engineering') # this always work? } rm_main = function(dat, in_rapidminer = T){ # macro inputs from UI (default of macros is -1) #### # either data source with known metadata table_in_known = '%{TABLE_IN_KNOWN}' # or new data with metadata table_in = '%{TABLE_IN}' col_predictor = '%{PREDICTOR}' col_label = '%{LABEL}' col_metric = '%{METRIC}' col_group = '%{GROUP}' # or metadata = '%{METADATA}' # metadata (role and datatype) about the columns. If have this, `column_in` and `group` are ignored # # don't do this step now (high automation) #### # # show user available algorithms based on metadata, and use chooses some of them if(in_rapidminer == F){ table_in_known = 'HHS_CLM_ROLLING_36_MONTHS_Jul14_provider_daily' } # now specify output table table_out = '%{TABLE_OUT}' # parse and organize metadata from different sources #### parsed = parse_metadata(table_in_known, table_in, col_predictor, col_label, col_metric, col_group, metadata, table_out) table_in = parsed[[1]] metadata = parsed[[2]] table_out = parsed[[3]] scenario = decide_scenario(metadata) cat('scenario:', scenario, '\n') cat('table_in:', table_in, '\n') cat('table_out:', table_out, '\n') }"/>
</process>
</process>
1 - 2 of
21
I have seen this before when my server didn't have access to a datasource that was needed or called within the script and the script was throwing an error. Not at my server right now, will try to look more into it tomorrow but wanted to point you in a hopefully useful direction!
