Cant initailize extension project
gabriel_nemeth
gabriel_nemeth New Altair Community Member
I followed the developer guide for eclipse, but after I run a initializeExtensionProject Gradle task it fails with following message:
Execution failed for task ':initializeExtensionProject'.
Details: http://pastebin.com/jnsJaHY5
Any idea what is causing this?
EDIT: if I ran the task in command line, it builds the project succesfully
Welcome!
  • mmichel
    mmichel New Altair Community Member
    it seems that gradle cannot retrieve the console via System.console. Can you please specify your eclipse and gradle plugin version?
  • gabriel_nemeth
    I'm using Eclipse Neon 4.6.0 and the plugin that I use is Gradle IDE Pack 3.8.x + 1.0.x
    I'm wondering if this issue can't be caused by android studio, as before it worked fine.
  • mmichel
    It seems that eclipse is unable to provide a console at this point. I'm afraid that this command currently needs to be executed via command line.
    If the the execution still fails, please make sure that gradle is not running as daemon (org.gradle.daemon=false).
Welcome!
Welcome!
