Error when installing Rapidminer Stuidio in Ubuntu 164
I am trying to install Rapidminer Studio ubuntu 16.04 and I`m getting this error:
~/rapidminer-studio$ ./RapidMiner-Studio.sh
RAPIDMINER_HOME is not set. Trying the directory '/home/daniel/Downloads/rapidminer-studio'...
Exception in thread "main" java.lang.NoClassDefFoundError: javax/xml/bind/DatatypeConverter
at com.rapidminer.license.verification.JarVerifier.verify(JarVerifier.java:130)
at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:284)
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.DatatypeConverter
at jdk.internal.loader.BuiltinClassLoader.loadClass(java.base@9-ea/BuiltinClassLoader.java:366)
at jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(java.base@9-ea/ClassLoaders.java:185)
at java.lang.ClassLoader.loadClass(java.base@9-ea/ClassLoader.java:419)
... 2 more
thanks!!! it's work for me:
if [ $# -gt 0 ]; then
eval \"$JAVA\" --add-modules=java.xml.bind $JVM_OPTIONS -cp \"${rmClasspath}\" com.rapidminer.launcher.GUILauncher \"$@\"
else
fi
First, If you don't have 8 installed you can do:
sudo apt install openjdk-8-jdk openjdk-8-jre
Then type:
sudo update-alternatives --config java
Output:
Type the selection ID to activate that version. e.g. in my case: 2
Java8 Activated.
Then do the following to run:
chmod +x RapidMiner-Studio.sh
sh RapidMiner-Studio.sh
Then type:
Output:
Java8 Activated.
looks like that for some reason the Java installation you are using does not contain javax.xml.bind.DatatypeConverter.
Please make sure to use Oracle Java 8 or OpenJDK 8 for RapidMiner Studio.
Marco
