Rapid Miner Server not Running
rabna134
rabna134 New Altair Community Member
Hello Rapid Miner Community
i have problem to run my rapidminer server . i installed rapidminer server completely and successfully but it is not start when i open "standalone.bat" then i get an error i don't understand why this occur so please help me ! i attached error snapshot .
i have laptop with following configuration
for testing i changed the RAM from 3GB to 4GB but still i have problem
i hope you will response as soon as possible .Thank You
Welcome!
  • IngoRM
    IngoRM New Altair Community Member
    It does not look like your system is fulfilling the system requirements (see: http://docs.rapidminer.com/server/installation/system-requirements.html).  You should have a machine with at least 8 Gb of memory to run Server.
    Best,
    Ingo
  • rabna134
    But my friend have pc with 64 bit os having 2 gb ram working fine after closing everything. but this laptop have 3 gb of ram but Os is 32 bit so is 32 bit can be issue??
    Thanks
  • Marco_Boeck
    Marco_Boeck New Altair Community Member
    generally speaking, a 32-bit system is not advised for RM Server. You just cannot get enough memory for some of the more complex tasks.
    In any case, what you can do to just get a taste of RM Server though is to reduce the maximum memory (Xmx) setting down to the mininmum memory setting (Xms).
    To do so, please see here and change the number in there to 1303M.
    Then try starting the Server again. If that also fails, it means you cannot even allocate 1,3 GB of memory which is the minimum amount of memory RM Server requires.
    Marco
  • ayisheshim_boga
    ayisheshim_boga New Altair Community Member
    same problem facing me also....my laptop...8GB RAM 64 BIT window 10
    i am trying to run rapid minor server but it is not starting .....Running RapidMiner Server as a service........not working it say's rapidminor server7_6_1 service on local computer starts and then stoped.some services stop authomatically.they are not in use by other services or programs...please help ...how to fix
    please .........
  • sgenzer
    sgenzer
    hello @ayisheshim_boga - happy to help but you need to please give us more information: server log, installation settings, etc...
    Scott
  • ayisheshim_boga
    i install the server successfully but i ca not access the web interface of rapid minor server.  to start running server......i am installing run as adminstartor...then i got the error
  • sgenzer
    sgenzer
    hello @ayisheshim_boga - I believe this is also a duplicate post.
    Scott
  • ershadalibaig_m
    ershadalibaig_m New Altair Community Member
    Hi Even i am not able to start the rapid miner server windows service after editing Active directory seetings.
    While starting the windows service,i am getting the error. Attaching the error for the same.
  • sgenzer
    sgenzer
    hello @ershadalibaig_m - can you please share your server log?
    https://docs.rapidminer.com/latest/server/administration/error-logs.html
    Scott
Welcome!
Welcome!
