I have tried to create an HTML report with the reporting extension and have created the following process:
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="7.2.000" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="7.2.000" expanded="true" height="68" name="Retrieve asiaCLC_ ARSUNEOBOTL Day" width="90" x="45" y="34">
        <parameter key="repository_entry" value="../../data/Triangl_SKU/asiaCLC_ ARSUNEOBOTL Day"/>
      <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="82" name="Generate Report" width="90" x="246" y="34">
        <parameter key="report_name" value="AsiaCLC"/>
        <parameter key="format" value="HTML"/>
        <parameter key="report_to_repository" value="true"/>
        <parameter key="repository_entry" value="AsiaCLC-Report"/>
        <parameter key="html_output_directory" value="C:\Users\suntietk\Documents\2_Big Data\RapidMiner\Report"/>
        <parameter key="html_logo_file" value="C:\Users\suntietk\Documents\_Orga\Vorlagen\Hellmann Worldwide Logistics RGB_small.png"/>
        <parameter key="html_image_format" value="png"/>
        <parameter key="image_col_span" value="8"/>
        <parameter key="image_row_span" value="17"/>
        <parameter key="page_size" value="A4"/>
        <parameter key="page_format" value="portrait"/>
        <parameter key="template_type" value="none"/>
        <parameter key="image_alignment" value="aspect_ratio"/>
        <parameter key="set_background_color" value="false"/>
        <parameter key="background_color" value="255,255,255"/>
        <parameter key="page_width" value="595"/>
        <parameter key="page_height" value="842"/>
        <parameter key="top_page_margin" value="36"/>
        <parameter key="bottom_page_margin" value="36"/>
        <parameter key="left_page_margin" value="36"/>
        <parameter key="right_page_margin" value="36"/>
        <parameter key="section_one_font_size" value="12.0"/>
        <parameter key="section_one_font_style_bold" value="false"/>
        <parameter key="section_one_font_style_italic" value="false"/>
        <parameter key="section_one_font_style_underline" value="false"/>
        <parameter key="section_one_font_style_strikethrough" value="false"/>
        <parameter key="section_one_font_color" value="0,0,0"/>
        <parameter key="section_two_font_size" value="12.0"/>
        <parameter key="section_two_font_style_bold" value="false"/>
        <parameter key="section_two_font_style_italic" value="false"/>
        <parameter key="section_two_font_style_underline" value="false"/>
        <parameter key="section_two_font_style_strikethrough" value="false"/>
        <parameter key="section_two_font_color" value="0,0,0"/>
        <parameter key="section_three_font_size" value="12.0"/>
        <parameter key="section_three_font_style_bold" value="false"/>
        <parameter key="section_three_font_style_italic" value="false"/>
        <parameter key="section_three_font_style_underline" value="false"/>
        <parameter key="section_three_font_style_strikethrough" value="false"/>
        <parameter key="section_three_font_color" value="0,0,0"/>
        <parameter key="section_four_font_size" value="12.0"/>
        <parameter key="section_four_font_style_bold" value="false"/>
        <parameter key="section_four_font_style_italic" value="false"/>
        <parameter key="section_four_font_style_underline" value="false"/>
        <parameter key="section_four_font_style_strikethrough" value="false"/>
        <parameter key="section_four_font_color" value="0,0,0"/>
        <parameter key="section_five_font_size" value="12.0"/>
        <parameter key="section_five_font_style_bold" value="false"/>
        <parameter key="section_five_font_style_italic" value="false"/>
        <parameter key="section_five_font_style_underline" value="false"/>
        <parameter key="section_five_font_style_strikethrough" value="false"/>
        <parameter key="section_five_font_color" value="0,0,0"/>
        <parameter key="text_content_font_size" value="12.0"/>
        <parameter key="text_content_font_style_bold" value="false"/>
        <parameter key="text_content_font_style_italic" value="false"/>
        <parameter key="text_content_font_style_underline" value="false"/>
        <parameter key="text_content_font_style_strikethrough" value="false"/>
        <parameter key="text_content_font_color" value="0,0,0"/>
        <parameter key="system_fonts" value="false"/>
        <parameter key="directory_fonts" value="false"/>
        <parameter key="table_column_number" value="8"/>
        <parameter key="table_header_color" value="128,128,128"/>
        <parameter key="table_row_color_one" value="255,255,255"/>
        <parameter key="table_row_color_two" value="192,192,192"/>
      <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="68" name="Report" width="90" x="380" y="34">
        <parameter key="specified" value="true"/>
        <parameter key="reportable_type" value="Data Table"/>
        <parameter key="renderer_name" value="Data View"/>
        <list key="parameters">
          <parameter key="attributes" value="Quantity_shipped|Date|prediction(Quantity_shipped)|"/>
          <parameter key="min_row" value="1"/>
          <parameter key="max_row" value="2147483647"/>
        </list>
        <parameter key="image_width" value="800"/>
        <parameter key="image_height" value="600"/>
      <connect from_op="Retrieve asiaCLC_ ARSUNEOBOTL Day" from_port="output" to_op="Generate Report" to_port="through 1"/>
      <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/>
      <connect from_op="Report" from_port="reportable out" to_port="result 1"/>
    </process>
</process>
Unfortunately I receive a java.io.FilePermission error saying "Access denied" for some tmp file (see screenshot below).
Since I don't why or where this file is needed, I have no idea how to fix this. Can anyone help?
Please note:
- PDF and Excel reports work fine with the process above
- HTML reports worked before I updated to RM 7.2 (I had 7.1.1 before)
- I already tried deinstalling and reinstalling the extension without success
Bets regards,
Saskia
