Rapidminer studio installation error Can't connect to X11 window server using
User: "AjiVarghese"
New Altair Community Member
Updated by Jocelyn
I am trying to run the rapidminer-studio-installer script .When I attempt to run the script (ubuntu 14.04) it errors out:
Jul 01, 2016 12:42:17 AM com.rapidminer.launcher.GUILauncher main
INFO: Launching RapidMiner, platform ANY
Exception in thread "main" java.awt.AWTError: Can't connect to X11 window server using 'localhost:10.0' as the value of the DISPLAY variable.
at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
at sun.awt.X11GraphicsEnvironment.access$200(X11GraphicsEnvironment.java:65)
at sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:115)
at java.security.AccessController.doPrivileged(Native Method)
at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:74)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at java.awt.GraphicsEnvironment.createGE(GraphicsEnvironment.java:103)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:82)
at com.rapidminer.gui.RapidMinerGUI.<clinit>(RapidMinerGUI.java:233)
at com.rapidminer.launcher.GUILauncher.registerGUIStartupListeners(GUILauncher.java:341)
at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:331)
OS
Ubuntu 14.04.4 LTS (GNU/Linux 3.13.0-91-generic x86_64)
What could be wrong here? Could you please suggest me.
1 - 1 of 11
    User: "Marco_Boeck"
    given that there is no Studio installer script (there is one for RapidMiner Server, though), you are talking about the regular script to start the GUI of RapidMiner Studio.
    The error indicates that your X Server is not running. You need that to be able to use the GUI of Studio.
    Marco
