Hi.
I have shut down the database before shutting down RapidMiner Server (7.1). Then RM Server refused to start with strange error messages concerning the db (tables were not there where they were supposed to be). Ive seen that it wants to delete a specific table so I just created it manually. Now it refuses to start up (completely, the http service is up but does give a white page) but without any error message. This is the server log:
11:58:39,096 INFO [org.jboss.modules] (main) JBoss Modules version 1.3.6.Final-redhat-1
11:58:39,393 INFO [org.jboss.msc] (main) JBoss MSC version 1.1.5.Final-redhat-1
11:58:39,534 INFO [org.jboss.as] (MSC service thread 1-6) JBAS015899: JBoss EAP 6.4.0.Alpha1 (AS 7.5.0.Final-redhat-15) starting
11:58:39,549 DEBUG [org.jboss.as.config] (MSC service thread 1-6) Configured system properties:
awt.toolkit = sun.awt.windows.WToolkit
com.sun.jndi.ldap.connect.pool.timeout = 300000
file.encoding = Cp1252
file.encoding.pkg = sun.io
file.separator = \
java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment
java.awt.printerjob = sun.awt.windows.WPrinterJob
java.class.path = E:\software\RapidMinerServer\jboss-modules.jar
java.class.version = 52.0
java.endorsed.dirs = C:\Program Files\Java\jre1.8.0_92\lib\endorsed
java.ext.dirs = C:\Program Files\Java\jre1.8.0_92\lib\ext;C:\windows\Sun\Java\lib\ext
java.home = C:\Program Files\Java\jre1.8.0_92
java.io.tmpdir = C:\Users\SVC_AN~1\AppData\Local\Temp\
java.library.path = C:\Program Files\Java\jre1.8.0_92\bin;C:\windows\Sun\Java\bin;C:\windows\system32;C:\windows;C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Teradata\Client\15.00\ODBC Driver for Teradata nt-x8664\Lib\;C:\Program Files (x86)\Teradata\Client\15.00\ODBC Driver for Teradata\Lib\;C:\Program Files\Teradata\Client\15.00\bin\;C:\Program Files (x86)\Teradata\Client\15.00\bin\;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\MySQL\MySQL Fabric 1.5 & MySQL Utilities 1.5\;C:\Program Files (x86)\MySQL\MySQL Fabric 1.5 & MySQL Utilities 1.5\Doctrine extensions for PHP\;C:\software\oracle;C:\Program Files\MySQL\MySQL Server 5.7\bin;E:\software\netcat-1.11;E:\software\python\anaconda;E:\software\python\anaconda\Scripts;E:\software\python\anaconda\Library\bin;E:\software\pgadmin\1.22;.
java.net.preferIPv4Stack = true
java.runtime.name = Java(TM) SE Runtime Environment
java.runtime.version = 1.8.0_92-b14
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.8
java.util.logging.manager = org.jboss.logmanager.LogManager
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.8.0_92
java.vm.info = mixed mode
java.vm.name = Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.8
java.vm.vendor = Oracle Corporation
java.vm.version = 25.92-b14
javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
jboss.home.dir = E:\software\RapidMinerServer
jboss.host.name = sw-fralpa-cod01
jboss.modules.dir = E:\software\RapidMinerServer\modules
jboss.modules.policy-permissions = true
jboss.modules.system.pkgs = org.jboss.byteman
jboss.node.name = sw-fralpa-cod01
jboss.qualified.host.name = sw-fralpa-cod01
jboss.server.base.dir = E:\software\RapidMinerServer\standalone
jboss.server.config.dir = E:\software\RapidMinerServer\standalone\configuration
jboss.server.data.dir = E:\software\RapidMinerServer\standalone\data
jboss.server.deploy.dir = E:\software\RapidMinerServer\standalone\data\content
jboss.server.log.dir = E:\software\RapidMinerServer\standalone\log
jboss.server.name = sw-fralpa-cod01
jboss.server.persist.config = true
jboss.server.temp.dir = E:\software\RapidMinerServer\standalone\tmp
line.separator =
logging.configuration = file:E:\software\RapidMinerServer\standalone\configuration/logging.properties
module.path = E:\software\RapidMinerServer\modules
org.jboss.boot.log.file = E:\software\RapidMinerServer\standalone\log\server.log
org.jboss.resolver.warning = true
org.xml.sax.driver = __redirected.__XMLReaderFactory
os.arch = amd64
os.name = Windows Server 2012 R2
os.version = 6.3
path.separator = ;
program.name = standalone.bat
sun.arch.data.model = 64
sun.boot.class.path = C:\Program Files\Java\jre1.8.0_92\lib\resources.jar;C:\Program Files\Java\jre1.8.0_92\lib\rt.jar;C:\Program Files\Java\jre1.8.0_92\lib\sunrsasign.jar;C:\Program Files\Java\jre1.8.0_92\lib\jsse.jar;C:\Program Files\Java\jre1.8.0_92\lib\jce.jar;C:\Program Files\Java\jre1.8.0_92\lib\charsets.jar;C:\Program Files\Java\jre1.8.0_92\lib\jfr.jar;C:\Program Files\Java\jre1.8.0_92\classes;E:\software\RapidMinerServer\jboss-modules.jar
sun.boot.library.path = C:\Program Files\Java\jre1.8.0_92\bin
sun.cpu.endian = little
sun.cpu.isalist = amd64
sun.desktop = windows
sun.io.unicode.encoding = UnicodeLittle
sun.java.command = E:\software\RapidMinerServer\jboss-modules.jar -mp E:\software\RapidMinerServer\modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=E:\software\RapidMinerServer
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = Cp1252
sun.management.compiler = HotSpot 64-Bit Tiered Compilers
sun.os.patch.level =
sun.stderr.encoding = cp437
sun.stdout.encoding = cp437
user.country = US
user.dir = E:\software\RapidMinerServer\bin
user.home = C:\Users\svc_analytics
user.language = en
user.name = svc_analytics
user.script =
user.timezone = Europe/Berlin
user.variant =
11:58:39,549 DEBUG [org.jboss.as.config] (MSC service thread 1-6) VM Arguments: -Xloggc:E:\software\RapidMinerServer\standalone\log\gc.log -verbose:gc -XX:+PrintGCDetails -XX:+PrintGCDateStamps -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=5 -XX:GCLogFileSize=3M -XX:-TraceClassUnloading -XX:+UseCompressedOops -Dprogram.name=standalone.bat -Xms1303M -Xmx129023M -XX:MaxPermSize=256M -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dcom.sun.jndi.ldap.connect.pool.timeout=300000 -Djboss.modules.policy-permissions=true -Djboss.modules.system.pkgs=org.jboss.byteman -Duser.country=US -Duser.language=en -Dorg.jboss.boot.log.file=E:\software\RapidMinerServer\standalone\log\server.log -Dlogging.configuration=file:E:\software\RapidMinerServer\standalone\configuration/logging.properties -Xbootclasspath/a:E:\software\RapidMinerServer\jboss-modules.jar
11:58:41,284 INFO [org.xnio] (MSC service thread 1-5) XNIO Version 3.0.12.GA-redhat-1
11:58:41,284 INFO [org.jboss.as.server] (Controller Boot Thread) JBAS015888: Creating http management service using socket-binding (management-http)
11:58:41,301 INFO [org.xnio.nio] (MSC service thread 1-5) XNIO NIO Implementation Version 3.0.12.GA-redhat-1
11:58:41,377 INFO [org.jboss.as.naming] (ServerService Thread Pool -- 39) JBAS011800: Activating Naming Subsystem
11:58:41,393 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 31) JBAS010280: Activating Infinispan subsystem.
11:58:41,424 WARN [org.jboss.as.txn] (ServerService Thread Pool -- 46) JBAS010153: Node identifier property is set to the default value. Please make sure it is unique.
11:58:41,440 INFO [org.jboss.as.jsf] (ServerService Thread Pool -- 37) JBAS012615: Activated the following JSF Implementations: [main, 1.2]
11:58:41,471 INFO [org.jboss.as.security] (ServerService Thread Pool -- 44) JBAS013371: Activating Security Subsystem
11:58:41,471 INFO [org.jboss.as.webservices] (ServerService Thread Pool -- 48) JBAS015537: Activating WebServices Extension
11:58:41,518 INFO [org.jboss.as.naming] (MSC service thread 1-10) JBAS011802: Starting Naming Service
11:58:41,518 INFO [org.jboss.as.connector.logging] (MSC service thread 1-3) JBAS010408: Starting JCA Subsystem (IronJacamar 1.0.30.Final-redhat-1)
11:58:41,534 INFO [org.jboss.as.mail.extension] (MSC service thread 1-9) JBAS015400: Bound mail session [java:/Mail]
11:58:41,534 INFO [org.jboss.remoting] (MSC service thread 1-5) JBoss Remoting version 3.3.4.Final-redhat-1
11:58:41,534 INFO [org.jboss.as.security] (MSC service thread 1-11) JBAS013370: Current PicketBox version=4.1.0.Final-redhat-1
11:58:41,549 INFO [org.jboss.as.connector.subsystems.datasources] (ServerService Thread Pool -- 27) JBAS010404: Deploying non-JDBC-compliant driver class org.postgresql.Driver (version 9.3)
11:58:41,909 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-15) JBWEB003001: Coyote HTTP/1.1 initializing on : http-/0.0.0.0:8080
11:58:41,924 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-15) JBWEB003000: Coyote HTTP/1.1 starting on: http-/0.0.0.0:8080
11:58:42,034 INFO [org.jboss.as.remoting] (MSC service thread 1-11) JBAS017100: Listening on 10.244.17.110:9999
11:58:42,034 INFO [org.jboss.as.remoting] (MSC service thread 1-9) JBAS017100: Listening on 0.0.0.0:4447
11:58:42,034 INFO [org.jboss.as.server.deployment.scanner] (MSC service thread 1-12) JBAS015012: Started FileSystemDeploymentService for directory E:\software\RapidMinerServer\standalone\deployments
11:58:42,049 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-11) JBAS010400: Bound data source [java:/jdbc/RapidAnalyticsDS]
11:58:42,112 INFO [org.jboss.ws.common.management] (MSC service thread 1-16) JBWS022052: Starting JBoss Web Services - Stack CXF Server 4.3.2.Final-redhat-1
11:58:42,174 INFO [org.jboss.as] (Controller Boot Thread) JBAS015961: Http management interface listening on http://10.244.17.110:9990/management
11:58:42,174 INFO [org.jboss.as] (Controller Boot Thread) JBAS015951: Admin console listening on http://10.244.17.110:9990
11:58:42,174 INFO [org.jboss.as] (Controller Boot Thread) JBAS015874: JBoss EAP 6.4.0.Alpha1 (AS 7.5.0.Final-redhat-15) started in 3594ms - Started 155 of 194 services (58 services are lazy, passive or on-demand)
What could be wrong here? Is there a way to do a failsafe start or to reinitialize the database managment subroutines in order to bring the db in a consistent state again?
Fabian Werner
