I am trying to set up a JDBC connection to Azure HDInsight Hive, however I need to specify precise options in the connection string as described here: https://azure.microsoft.com/en-us/documentation/articles/hdinsight-connect-hive-jdbc-driver/ (the relevant connection string template is: jdbc:hive2://CLUSTERNAME.azurehdinsight.net:443/default;ssl=true?hive.server2.transport.mode=http;hive.server2.thrift.http.path=/hive2).
Is it possible to set up a custom DB connection for RapidMiner Studio (v.7.1) like this ?
I don't see a way to add parameters to the JDBC connection string.
Thanks for your help in advance!
