Hello everyone,
I'm doing a topology-frequency optimization with Optistruct on a simple simple beam as an exercise to learn how to use the Overhang constraint.
The objective function is to increase the first three natural frequencies, and at the same time I want to keep the volume of the beam under 30% of the original volume.
Without any other constraints, the software simply reduces the volume of the structure to the minimal volume I've allowed him to use with the frozen elements I put at the base of the beam, which makes sense.
However, when I put other frozen Elements at the top of the beam and used the OHA constraint, here are the results I've had: (The elements with a density under 0,014 are not displayed)
I was expecting a design with some kind of lattice structure that would support the top of the beam.
Here is what I've done to parametrize my optimization:
I've included the two small areas at the top and the bottom
in the design space and have set their densities equal to 1 as a Volfrac constraint. But as you can see on this graph, this design constraint is only respected on the green area at the base of the beam, while it isn't respected at the top of the beam, and the optimization stopped even though I had put the maximum number of iterations at 100.
| Volfrac at the top of the beam, red area | Volfrac at the base of the beam, green area |
I've used the BIGOPT Optimization algorithm and set the minimal dimension equal to 3.1 times the size of an element in the parameters of my design variable.
I've also tried an other method, which is to not include the two areas at the top and the bottom in the design space, and to parametrize the Overhang so that the Non-design spaces and the holes are not self-supporting,
so that the area at the top should be supported by material, but it doesn't work neither.
Would someone have an Idea as to why there isn't some kind of support structure for the top of the beam, and why the optimization process stops even though my VolFrac constraint isn't satisfied?
regards,
Clement
