"Macros with radoop"
User: "DocMusher"
New Altair Community Member
Updated by Jocelyn
Are macros possible with in a radoop nest?
Cheers
Sven
In fact the next xml  I would like to change to be able to run it in a radoop nest:
<process version="6.4.000">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Test20150711(4)" width="90" x="29" y="74">
       <parameter key="repository_entry" value="//Local Repository/data/Test20150711(4)"/>
     <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples" width="90" x="179" y="72">
       <parameter key="invert_filter" value="true"/>
       <list key="filters_list">
         <parameter key="filters_entry_key" value="test.equals.211"/>
       </list>
     <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values" width="90" x="244" y="364">
       <parameter key="attribute" value="patient"/>
         <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (2)" width="90" x="51" y="35">
           <parameter key="parameter_string" value="patient = %{loop_value}"/>
           <parameter key="condition_class" value="attribute_value_filter"/>
           <list key="filters_list"/>
         <operator activated="true" class="aggregate" compatibility="6.4.000" expanded="true" height="76" name="Aggregate" width="90" x="209" y="44">
           <list key="aggregation_attributes"/>
           <parameter key="group_by_attributes" value="icustay_expire_flg|patient|value1|charttime|test"/>
         <operator activated="true" class="sort" compatibility="6.4.000" expanded="true" height="76" name="Sort" width="90" x="376" y="30">
           <parameter key="attribute_name" value="charttime"/>
         <operator activated="true" class="extract_macro" compatibility="6.4.000" expanded="true" height="60" name="Extract Macro" width="90" x="493" y="32">
           <parameter key="macro" value="mincharttime"/>
           <parameter key="macro_type" value="data_value"/>
           <parameter key="example_index" value="1"/>
           <list key="additional_macros"/>
         <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="375" y="130">
             <parameter key="mincharttime" value="%{mincharttime}"/>
           </list>
         <connect from_port="example set" to_op="Filter Examples (2)" to_port="example set input"/>
         <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
         <connect from_op="Aggregate" from_port="example set output" to_op="Sort" to_port="example set input"/>
         <connect from_op="Aggregate" from_port="original" to_op="Generate Attributes (2)" to_port="example set input"/>
         <connect from_op="Sort" from_port="example set output" to_op="Extract Macro" to_port="example set"/>
         <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="out 1"/>
       </process>
     <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="2144" y="124"/>
     <operator activated="true" class="guess_types" compatibility="6.4.000" expanded="true" height="76" name="Guess Types" width="90" x="2290" y="120"/>
     <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="2415" y="120">
         <parameter key="diffcharttime" value="(charttime-mincharttime)/60"/>
       </list>
     <operator activated="true" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes (3)" width="90" x="2539" y="119">
       <parameter key="attributes" value="patient|diffcharttime|test|value1|icustay_expire_flg"/>
     <operator activated="true" class="store" compatibility="6.4.000" expanded="true" height="60" name="Store (2)" width="90" x="2662" y="118">
       <parameter key="repository_entry" value="../data/result"/>
     <connect from_op="Retrieve Test20150711(4)" from_port="output" to_op="Filter Examples" to_port="example set input"/>
     <connect from_op="Filter Examples" from_port="example set output" to_op="Loop Values" to_port="example set"/>
     <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/>
     <connect from_op="Append" from_port="merged set" to_op="Guess Types" to_port="example set input"/>
     <connect from_op="Guess Types" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
     <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/>
     <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Store (2)" to_port="input"/>
     <connect from_op="Store (2)" from_port="through" to_port="result 1"/>
   </process>
</process>
This is where I landed or crashed:
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
     <operator activated="true" class="radoop:radoop_nest" compatibility="2.1.001" expanded="true" height="76" name="Radoop Nest" width="90" x="23" y="28">
       <parameter key="connection" value="cds.analytics.vancis.nl"/>
         <operator activated="true" class="radoop:retrieve" compatibility="2.1.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="38">
           <parameter key="table" value="test20150711"/>
         <operator activated="true" class="radoop:loop" compatibility="2.1.001" expanded="true" height="76" name="Loop (Radoop)" width="90" x="285" y="35">
           <parameter key="set_iteration_macro" value="true"/>
           <parameter key="macro_name" value="patient"/>
             <operator activated="true" class="radoop:example_filter" compatibility="2.1.001" expanded="true" height="76" name="Filter Examples" width="90" x="59" y="41">
               <parameter key="parameter_string" value="patient=%{loop_value}"/>
             <operator activated="true" class="radoop:aggregate" compatibility="2.1.001" expanded="true" height="76" name="Aggregate" width="90" x="179" y="43">
               <parameter key="group_by_attributes" value="icustay_expire_flg|patient|charttime|test|value1|"/>
             <operator activated="true" class="radoop:attribute_generate" compatibility="2.1.001" expanded="true" height="76" name="Generate Attributes" width="90" x="318" y="167">
               <parameter key="attribute name" value="mincharttime"/>
               <parameter key="attribute expression" value="%{mincharttime}"/>
               <list key="new_attributes"/>
             <operator activated="true" class="radoop:sort" compatibility="2.1.001" expanded="true" height="76" name="Sort" width="90" x="319" y="39">
               <parameter key="sort attribute" value="charttime"/>
               <list key="additional attributes"/>
             <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/>
             <connect from_op="Filter Examples" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
             <connect from_op="Aggregate" from_port="original" to_op="Generate Attributes" to_port="example set input"/>
             <connect from_op="Sort" from_port="example set output" to_port="output 1"/>
             <portSpacing port="sink_output 1" spacing="0"/>
             <portSpacing port="sink_output 2" spacing="0"/>
           </process>
         <connect from_op="Retrieve" from_port="output" to_op="Loop (Radoop)" to_port="input 1"/>
         <connect from_op="Loop (Radoop)" from_port="output 1" to_port="output 1"/>
       </process>
     <connect from_op="Radoop Nest" from_port="output 1" to_port="result 1"/>
   </process>
</process>
Any suggestions?
Cheers
Sven
1 - 3 of 31
    User: "MariusHelf"
    Hi Sven,
    inside the Nest the use of macros is limited. This is because the complete Hive statement is created before the process enters the nest. So in your specific case you would need to drag the loop out of the nest instead of looping inside the nest.
    Cheers,
    ~Marius
    User: "DocMusher"
    OP
    Hi Marius,
    thanks for the reply, BUT, the reason I used the Radoop nest is the 40GB vs the 8GB on my laptop. Quite frustrating executing the process on my local machine always stops because of memory shortage even with preprocessing.
    Sven
    User: "MariusHelf"
    Sven, what about something like the process below?
    Of course you need to replace the standard operators with their Radoop pendants in the Nests.
    ~Marius
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Test20150711(4)" width="90" x="45" y="30">
          <operator activated="true" class="radoop:radoop_nest" compatibility="2.3.001" expanded="true" height="76" name="Radoop Nest" width="90" x="45" y="210">
            <enumeration key="tables_to_reload"/>
              <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Test20150711(4) (2)" width="90" x="45" y="30">
              <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (3)" width="90" x="246" y="30">
                </list>
              <connect from_op="Retrieve Test20150711(4) (2)" from_port="output" to_op="Filter Examples (3)" to_port="example set input"/>
              <connect from_op="Filter Examples (3)" from_port="example set output" to_port="output 1"/>
            </process>
          <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="60" name="Loop Values (2)" width="90" x="380" y="210">
              <operator activated="true" class="radoop:radoop_nest" compatibility="2.3.001" expanded="true" height="60" name="Radoop Nest (2)" width="90" x="246" y="30">
                  <operator activated="false" class="sort" compatibility="6.4.000" expanded="true" height="76" name="Sort (2)" width="90" x="447" y="30">
                  <operator activated="false" class="extract_macro" compatibility="6.4.000" expanded="true" height="60" name="Extract Macro (2)" width="90" x="581" y="30">
                  <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Test20150711(4) (3)" width="90" x="45" y="210">
                  <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (4)" width="90" x="179" y="210">
                  <operator activated="true" class="aggregate" compatibility="6.4.000" expanded="true" height="76" name="Aggregate (2)" width="90" x="337" y="219">
                  <operator activated="true" class="radoop:aggregate" compatibility="2.3.001" expanded="true" height="76" name="Aggregate (3)" width="90" x="514" y="120">
                      <parameter key="date" value="maximum"/>
                    </list>
                    <description align="center" color="transparent" colored="false" width="126">replace sort+extract by aggregation</description>
                  <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes (3)" width="90" x="503" y="305">
                    </list>
                  <operator activated="true" class="radoop:join" compatibility="2.3.001" expanded="true" height="76" name="Join" width="90" x="648" y="255">
                    <list key="key_attributes"/>
                    <description align="center" color="transparent" colored="false" width="126">should be a cartesian product if join key is not selected</description>
                  <operator activated="true" class="radoop:append" compatibility="2.3.001" expanded="true" height="76" name="Append (2)" width="90" x="782" y="255">
                    <parameter key="tablename" value="tableX"/>
                  <connect from_op="Retrieve Test20150711(4) (3)" from_port="output" to_op="Filter Examples (4)" to_port="example set input"/>
                  <connect from_op="Filter Examples (4)" from_port="example set output" to_op="Aggregate (2)" to_port="example set input"/>
                  <connect from_op="Aggregate (2)" from_port="example set output" to_op="Aggregate (3)" to_port="example set input"/>
                  <connect from_op="Aggregate (2)" from_port="original" to_op="Generate Attributes (3)" to_port="example set input"/>
                  <connect from_op="Aggregate (3)" from_port="example set output" to_op="Join" to_port="left"/>
                  <connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Join" to_port="right"/>
                  <connect from_op="Join" from_port="join" to_op="Append (2)" to_port="example set input"/>
                </process>
            </process>
          <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples" width="90" x="246" y="30">
            </list>
          <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values" width="90" x="380" y="30">
                </list>
            </process>
          <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="514" y="30"/>
          <operator activated="true" class="radoop:radoop_nest" compatibility="2.3.001" expanded="true" height="76" name="Radoop Nest (3)" width="90" x="648" y="210">
              <operator activated="true" class="radoop:retrieve" compatibility="2.3.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
                <parameter key="table" value="tableX"/>
              <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes (4)" width="90" x="179" y="30">
                </list>
              <operator activated="true" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes (2)" width="90" x="313" y="30">
              <operator activated="true" class="store" compatibility="6.4.000" expanded="true" height="60" name="Store (3)" width="90" x="447" y="30">
              <connect from_op="Retrieve" from_port="output" to_op="Generate Attributes (4)" to_port="example set input"/>
              <connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
              <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Store (3)" to_port="input"/>
              <connect from_op="Store (3)" from_port="through" to_port="output 1"/>
            </process>
          <operator activated="true" class="guess_types" compatibility="6.4.000" expanded="true" height="76" name="Guess Types" width="90" x="648" y="30"/>
          <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="782" y="30">
            </list>
          <operator activated="true" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes (3)" width="90" x="916" y="30">
          <operator activated="true" class="store" compatibility="6.4.000" expanded="true" height="60" name="Store (2)" width="90" x="1050" y="30">
          <connect from_op="Radoop Nest" from_port="output 1" to_op="Loop Values (2)" to_port="example set"/>
        </process>
    </process>
