"Radoop Connection: Full Test Error"
I have a CDH5 4 Nodes cluster that I want to connect to using radoop and rapidminer. I am getting the error below when running distributed file system upload:
[May 19, 2015 5:33:09 PM]: Distributed file system upload started.
[May 19, 2015 5:37:10 PM] SEVERE: Test data upload to the distributed file system timed out. Please check the NameNode and DataNode services and their logs for traces of errors.
I have opened all necessary ports, for your information.
Thanks in advance for your help.
Below please find the full test log:
[May 19, 2015 5:32:58 PM]: Connection test for 'master.example.com' started.
[May 19, 2015 5:32:58 PM]: Hive server 2 connection (???.???.???.??:10000) test started.
[May 19, 2015 5:32:59 PM]: Hive server 2 connection test succeeded.
[May 19, 2015 5:32:59 PM]: Retrieving required configuration properties...
[May 19, 2015 5:33:00 PM]: Successfully fetched property: yarn.resourcemanager.scheduler.address
[May 19, 2015 5:33:00 PM]: Successfully fetched property: yarn.resourcemanager.resource-tracker.address
[May 19, 2015 5:33:00 PM]: Successfully fetched property: yarn.resourcemanager.admin.address
[May 19, 2015 5:33:00 PM]: Successfully fetched property: yarn.application.classpath
[May 19, 2015 5:33:00 PM]: MapReduce Home added to yarn.application.classpath ($HADOOP_MAPRED_HOME/*,$HADOOP_MAPRED_HOME/lib/*)
[May 19, 2015 5:33:00 PM]: Successfully fetched property: mapreduce.jobhistory.address
[May 19, 2015 5:33:01 PM]: Distributed file system test started.
[May 19, 2015 5:33:01 PM]: Distributed file system test succeeded.
[May 19, 2015 5:33:01 PM]: MapReduce test started.
[May 19, 2015 5:33:02 PM]: MapReduce test succeeded.
[May 19, 2015 5:33:02 PM]: Radoop temporary directory test started.
[May 19, 2015 5:33:02 PM]: Radoop temporary directory test succeeded.
[May 19, 2015 5:33:02 PM]: MapReduce staging directory test started.
[May 19, 2015 5:33:02 PM]: MapReduce staging directory test succeeded.
[May 19, 2015 5:33:02 PM]: Connection test for 'master.example.com' completed successfully.
[May 19, 2015 5:33:07 PM]: --------------------------------------------------
[May 19, 2015 5:33:07 PM]: Connection test for 'master.example.com' started.
[May 19, 2015 5:33:07 PM]: Hive server 2 connection (???.???.???.??:10000) test started.
[May 19, 2015 5:33:07 PM]: Hive server 2 connection test succeeded.
[May 19, 2015 5:33:07 PM]: Retrieving required configuration properties...
[May 19, 2015 5:33:09 PM]: Successfully fetched property: yarn.resourcemanager.scheduler.address
[May 19, 2015 5:33:09 PM]: Successfully fetched property: yarn.resourcemanager.resource-tracker.address
[May 19, 2015 5:33:09 PM]: Successfully fetched property: yarn.resourcemanager.admin.address
[May 19, 2015 5:33:09 PM]: Successfully fetched property: yarn.application.classpath
[May 19, 2015 5:33:09 PM]: MapReduce Home added to yarn.application.classpath ($HADOOP_MAPRED_HOME/*,$HADOOP_MAPRED_HOME/lib/*)
[May 19, 2015 5:33:09 PM]: Successfully fetched property: mapreduce.jobhistory.address
[May 19, 2015 5:33:09 PM]: Distributed file system test started.
[May 19, 2015 5:33:09 PM]: Distributed file system test succeeded.
[May 19, 2015 5:33:09 PM]: MapReduce test started.
[May 19, 2015 5:33:09 PM]: MapReduce test succeeded.
[May 19, 2015 5:33:09 PM]: Radoop temporary directory test started.
[May 19, 2015 5:33:09 PM]: Radoop temporary directory test succeeded.
[May 19, 2015 5:33:09 PM]: MapReduce staging directory test started.
[May 19, 2015 5:33:09 PM]: MapReduce staging directory test succeeded.
[May 19, 2015 5:33:09 PM]: Connection test for 'master.example.com' completed successfully.
[May 19, 2015 5:33:09 PM]: --------------------------------------------------
[May 19, 2015 5:33:09 PM]: Integration test for 'master.example.com' started.
[May 19, 2015 5:33:09 PM]: The test may require several minutes to complete.
