<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="set_macros" compatibility="6.4.000-SNAPSHOT" expanded="true" height="76" name="Set Macros" width="90" x="45" y="30"> <list key="macros"> <parameter key="step_size" value="10000"/> </list> </operator> <operator activated="true" class="loop" compatibility="6.4.000-SNAPSHOT" expanded="true" height="76" name="Loop" width="90" x="179" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="i"/> <parameter key="iterations" value="5"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="6.4.000-SNAPSHOT" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="macro_start" value="%{step_size} * (%{i}-1)"/> <parameter key="macro_end" value="%{step_size} * %{i}"/> </list> </operator> <operator activated="true" class="read_database" compatibility="6.4.000-SNAPSHOT" expanded="true" height="60" name="Read Database" width="90" x="179" y="30"> <parameter key="connection" value="Local"/> <parameter key="query" value="SELECT * FROM `big` WHERE id > %{macro_start} AND id < %{macro_end}"/> <enumeration key="parameters"/> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Read Database" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Set Macros" from_port="through 1" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
