I'm attempting to execute a stored procedure with the Read Database operator and I receive an error, saying "executeQuery only accepts the SELECT statement".
Is there a special technique I need to use to pass parameters to a stored procedure so that I can read the results into an example set? I thought about the the Execute SQL operator, but that won't work.
Thanks for the help..code below.
-Eric
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_database" compatibility="5.3.015" expanded="true" height="60" name="Read Database" width="90" x="45" y="19">
<parameter key="connection" value="TestQuery"/>
<parameter key="query" value="EXEC GetRemainingRequests
@Resource=Trends"/>
<enumeration key="parameters"/>
<connect from_op="Read Database" from_port="output" to_port="result 1"/>
</process>
</process>
