Hi, I'm new to rapidminer. I'm trying to execute this simple process using java code
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve model" width="90" x="45" y="75">
<parameter key="repository_entry" value="//Local Repository/data/model"/>
<operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve testing" width="90" x="45" y="210">
<parameter key="repository_entry" value="//Local Repository/data/testing"/>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="313" y="75">
<connect from_op="Retrieve model" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Retrieve testing" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
I need to change the repository_entry value of the two retrieve operators. I'm using the setParameter method
Operator opRetModel = process.getOperator("Retrieve model");
opRetModel.setParameter(???,model path)
but I don't understand what to use as first parameter to specify the path of the saved model.
I've read the question n 6 at this page
http://rapid-i.com/rapidforum/index.php/topic,5807.0.html but I don't understand what is that class SingleDocumentInputOperator.
Thanks for your help.
