MemoryExampleTable table = new MemoryExampleTable(listOfAtts);for (ExampleSet exSet : listOfExampleSets) { for (Example e : exSet) { table.addDataRow(e.getDataRow()); }}ExampleSet exSet = table.createExampleSet();
</code>import pandas as pd # Initialize an empty DataFrame to store the combined tables combined_table = pd.DataFrame(columns=["USER_ID", "ITEM_ID"]) # Example loop (replace this with your actual loop) for value in [23, 54, ...]: # Add all your loop values # Assuming you have a function to generate each table based on the loop value table_for_value = generate_table(value) # Append the table for the current value to the combined_table combined_table = pd.concat([combined_table, table_for_value], ignore_index=True) # Display the combined table print(combined_table)</pre><div><br>In this example:<br><ul><li>Replace <code>[23, 54, ...]
pd.concat
ignore_index=True
