Error reading a classifier saved in default (xml compressed) or binary formats
szabel
szabel New Altair Community Member
Version: Rapid Miner 4.4 (Yes I know that its an old version)
Error:
com.rapidminer.operator.UserError: Could not read file '<omitted>/RapidMinerData/Test/cl
assifier.mod': Cannot read from XML stream, wrong format:  : only whitespace content allowed before start tag and not
? (position: START_DOCUMENT seen ?... @1:1) .
        at com.rapidminer.operator.io.ModelLoader.apply(ModelLoader.java:97)
        at com.rapidminer.operator.Operator.apply(Operator.java:666)
        at com.rapidminer.operator.OperatorChain.apply(OperatorChain.java:416)
        at com.rapidminer.Process.run(Process.java:695)
        at com.rapidminer.Process.run(Process.java:665)
        at com.rapidminer.Process.run(Process.java:655)
        at machine_learning_service.RapidMinerTester.test(RapidMinerTester.java:139)
        at machine_learning_service.Candidate.act(Candidate.java:352)
        at machine_learning_service.RapidMinerService.main(RapidMinerService.java:307)
Caused by: java.io.StreamCorruptedException: invalid stream header: 3F080000
        at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:781)
        at java.io.ObjectInputStream.<init>(ObjectInputStream.java:278)
        at com.rapidminer.operator.io.ModelLoader.apply(ModelLoader.java:76)
        ... 9 more
This happens when I change the process config xml
    <parameter key="logverbosity" value="off"/>
    <operator name="Input" class="ExampleSource">
        <parameter key="attributes" value="<omitted>/RapidMinerData/Train/AttributeDescriptors/test.aml"/>
    <operator name="NaiveBayes" class="NaiveBayes">
    <operator name="ModelWriter" class="ModelWriter">
        <parameter key="model_file" value="<omitted>/RapidMinerData/Train/classifier_return.mod"/>
      <parameter key="output_type"    value="XML"/>
and am reading in using
<operator name = "Root" class="Process" expanded="yes">
        <parameter key="attributes" value="<omitted>/RapidMinerData/Test/AttributeDescriptors/test.aml"/>
    <operator name="ModelLoader" class="ModelLoader">
        <parameter key="model_file" value="<omitted>/RapidMinerData/Test/classifier.mod"/>
    <operator name="Applier" class="ModelApplier">
        <list key="application_parameters">
        </list>
    <operator name="BinominalClassificationPerformance" class="BinominalClassificationPerformance">
        <parameter key="false_negative" value="true"/>
        <parameter key="false_positive" value="true"/>
        <parameter key="sensitivity" value="true"/>
        <parameter key="specificity" value="true"/>
        <parameter key="true_negative" value="true"/>
        <parameter key="true_positive" value="true"/>
    <operator name="ProcessLog" class="ProcessLog">
        <parameter key="filename" value="<omitted>/RapidMinerData/Test/statistics.per"/>
        <list key="log">
          <parameter key="false_positive"      value="operator.BinominalClassificationPerformance.value.false_positive"/>
          <parameter key="false_negative" value="operator.BinominalClassificationPerformance.value.false_negative"/>
          <parameter key="true_positive" value="operator.BinominalClassificationPerformance.value.true_positive"/>
          <parameter key="true_negative" value="operator.BinominalClassificationPerformance.value.true_negative"/>
          <!--<parameter key="AUC" value="operator.BinominalClassificationPerformance.value.AUC"/>-->
          <parameter key="sensitivity" value="operator.BinominalClassificationPerformance.value.sensitivity"/>
          <parameter key="specificity" value="operator.BinominalClassificationPerformance.value.specificity"/>
        </list>
        <parameter key="persistent" value="true"/>
Any help will be greatly appreciated
Welcome!
  • homburg
    homburg New Altair Community Member
    Hello szabel,
    is
     '<omitted>/RapidMinerData/Test/classifier.mod'
    really your file system input path? This might be problematic due to the "<" ">" characters in the xml file. Please try a full qualified path insted.
    Cheers,
    Helge
  • szabel
    No,  <omitted> is not actually there. I had to obfuscate some of the example... There is an actual valid path there and valid permissions; the only change is that I am taking the default (Zipped XML) and not specifying plain vanilla XML.
    Thank you,
    Stephen
  • homburg
    Looks like your model file is broken. Have you tried to recreate it?
    Another option might be that there has been a bug in the model writer those days. I'd highly recommend to upgrade to a more recent version. RapidMiner 5.3 is open source and freely available without any restrictions: http://sourceforge.net/projects/rapidminer/
    Cheers,
    Helge
  • szabel
    Yeah, I can try that... I was hoping that since it works when specifying XML that I was just missing a parameter that I was not seeing in the documentation.
Welcome!
Welcome!
