<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.003" expanded="true" height="60" name="Ripley-Set" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Ripley-Set"/> </operator> <operator activated="true" class="k_means" compatibility="6.0.003" expanded="true" height="76" name="Clustering" width="90" x="179" y="30"/> <operator activated="true" class="write_excel" compatibility="6.0.003" expanded="true" height="76" name="Write Excel" width="90" x="313" y="75"> <parameter key="excel_file" value="C:\Users\fras\Desktop\cluster.xls"/> </operator> <connect from_op="Ripley-Set" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/> <connect from_op="Clustering" from_port="clustered set" to_op="Write Excel" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
