I just follow the "hew to extend rapidminer 5" paper, when I finish a operator cloass, creat and move a '.jar' into plugins folder, I can't see my operator in the left side "operators" menu when I excute my Rapidminer(Unuk). I am not sure that cause the build.xml or operator.xml?
here shows some informations:
Buildfile: /home/john624/workspace/Paraminer/build.xml clean: [echo] Cleaning... [delete] Deleting directory /home/john624/workspace/Paraminer/build [delete] Deleting directory /home/john624/workspace/Paraminer/javadoc [mkdir] Created dir: /home/john624/workspace/Paraminer/build [mkdir] Created dir: /home/john624/workspace/Paraminer/javadoc version.get: [echo] Long version: ${extension.version}.${extension.revision}.${extension.update}; short version: ${extension.version}.${extension.revision} init.setEncoding: init: [taskdef] Could not load definitions from resource antlib.xml. It could not be found. [taskdef] Could not load definitions from resource org/freecompany/redline/ant/antlib.xml. It could not be found. [copy] Warning: Could not find file /home/john624/workspace/Paraminer/ant/jsch-0.1.42.jar to copy. init.setEncoding: copy-resources: [echo] Copying resources... [copy] Copying 10 files to /home/john624/workspace/Paraminer/build changes.testExistence: merge.changes: prepare_agpl: build: [echo] build.no_agpl=${build.no_agpl} clean: clean_agpl: build.rm: build.dependencies.prepare.set: build.dependencies.prepare.unset: [echo] No dependencies defined for Template. build.dependencies: [echo] Building plugin dependencies of Template... [echo] ...Finished [echo] RapidMiner Extension Template: Compile with Java from dir: /usr/lib/jvm/java-7-openjdk-i386/jre [echo] RapidMiner Extension Template: using Java version: 1.7.0_51 [javac] /home/john624/workspace/RapidMiner_Unuk/build_extension.xml:162: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [javac] Compiling 9 source files to /home/john624/workspace/Paraminer/build [javac] warning: [options] bootstrap class path not set in conjunction with -source 1.6 [javac] /home/john624/workspace/Paraminer/src/com/rapidminer/Numerical2DateOperator.java:27: warning: [deprecation] <T>getData() in Port has been deprecated [javac] ExampleSet exampleSet = exampleSetInput.getData(); [javac] ^ [javac] where T is a type-variable: [javac] T extends IOObject declared in method <T>getData() [javac] 2 warnings unzipLibs: [unjar] Expanding: /home/john624/workspace/Paraminer/lib/vldocking.jar into /home/john624/workspace/RapidMiner_Unuk/release/libfiles createJar: [echo] Creating jar... [echo] Manifest Classpath: vldocking.jar /home/john624/workspace/RapidMiner_Unuk/lib/SassyReader-0.5.jar /home/john624/workspace/RapidMiner_Unuk/lib/blas.jar /home/john624/workspace/RapidMiner_Unuk/lib/collections-generic.jar /home/john624/workspace/RapidMiner_Unuk/lib/colt.jar /home/john624/workspace/RapidMiner_Unuk/lib/commons-codec-1.4.jar /home/john624/workspace/RapidMiner_Unuk/lib/commons-collections.jar /home/john624/workspace/RapidMiner_Unuk/lib/commons-httpclient-3.1.jar /home/john624/workspace/RapidMiner_Unuk/lib/commons-lang-2.4.jar /home/john624/workspace/RapidMiner_Unuk/lib/commons-logging-1.1.jar /home/john624/workspace/RapidMiner_Unuk/lib/concurrent.jar /home/john624/workspace/RapidMiner_Unuk/lib/dom4j-1.6.1.jar /home/john624/workspace/RapidMiner_Unuk/lib/encog.jar /home/john624/workspace/RapidMiner_Unuk/lib/groovy-all-1.7.7.jar /home/john624/workspace/RapidMiner_Unuk/lib/itextpdf-5.3.3.jar /home/john624/workspace/RapidMiner_Unuk/lib/ivy-2.2.0.jar /home/john624/workspace/RapidMiner_Unuk/lib/jama.jar /home/john624/workspace/RapidMiner_Unuk/lib/jcommon.jar /home/john624/workspace/RapidMiner_Unuk/lib/jep.jar /home/john624/workspace/RapidMiner_Unuk/lib/jfreechart.jar /home/john624/workspace/RapidMiner_Unuk/lib/jmathplot.jar /home/john624/workspace/RapidMiner_Unuk/lib/joone-engine.jar /home/john624/workspace/RapidMiner_Unuk/lib/jugpreview.jar /home/john624/workspace/RapidMiner_Unuk/lib/jung-algorithms.jar /home/john624/workspace/RapidMiner_Unuk/lib/jung-api.jar /home/john624/workspace/RapidMiner_Unuk/lib/jung-graph-impl.jar /home/john624/workspace/RapidMiner_Unuk/lib/jung-visualization.jar /home/john624/workspace/RapidMiner_Unuk/lib/junit.jar /home/john624/workspace/RapidMiner_Unuk/lib/jxl.jar /home/john624/workspace/RapidMiner_Unuk/lib/kdb.jar /home/john624/workspace/RapidMiner_Unuk/lib/launcher.jar /home/john624/workspace/RapidMiner_Unuk/lib/looks.jar /home/john624/workspace/RapidMiner_Unuk/lib/mail.jar /home/john624/workspace/RapidMiner_Unuk/lib/microba.jar /home/john624/workspace/RapidMiner_Unuk/lib/poi-3.8-20120326.jar /home/john624/workspace/RapidMiner_Unuk/lib/poi-excelant-3.8-20120326.jar /home/john624/workspace/RapidMiner_Unuk/lib/poi-ooxml-3.8-20120326.jar /home/john624/workspace/RapidMiner_Unuk/lib/poi-ooxml-schemas-3.8-20120326.jar /home/john624/workspace/RapidMiner_Unuk/lib/poi-scratchpad-3.8-20120326.jar /home/john624/workspace/RapidMiner_Unuk/lib/rapidminer.jar /home/john624/workspace/RapidMiner_Unuk/lib/rm_doc.jar /home/john624/workspace/RapidMiner_Unuk/lib/rsyntaxtextarea.jar /home/john624/workspace/RapidMiner_Unuk/lib/slf4j-api-1.6.4.jar /home/john624/workspace/RapidMiner_Unuk/lib/slf4j-simple-1.6.4.jar /home/john624/workspace/RapidMiner_Unuk/lib/swingx-all-1.6.4.jar /home/john624/workspace/RapidMiner_Unuk/lib/vldocking.jar /home/john624/workspace/RapidMiner_Unuk/lib/ws-commons-util-1.0.2.jar /home/john624/workspace/RapidMiner_Unuk/lib/xmlbeans-2.3.0.jar /home/john624/workspace/RapidMiner_Unuk/lib/xmlpull.jar /home/john624/workspace/RapidMiner_Unuk/lib/xmlrpc-client-3.1.3.jar /home/john624/workspace/RapidMiner_Unuk/lib/xmlrpc-common-3.1.3.jar /home/john624/workspace/RapidMiner_Unuk/lib/xpp3.jar /home/john624/workspace/RapidMiner_Unuk/lib/xstream.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-export.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphics2d.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphicsio-emf.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphicsio-pdf.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphicsio-ps.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphicsio-svg.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphicsio-swf.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-graphicsio.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-io.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-swing.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-util.jar /home/john624/workspace/RapidMiner_Unuk/lib/freehep/freehep-xml.jar /home/john624/workspace/RapidMiner_Unuk/lib/jdbc/hsqldb.jar /home/john624/workspace/RapidMiner_Unuk/lib/jdbc/iijdbc-10.0-4.0.6.jar /home/john624/workspace/RapidMiner_Unuk/lib/jdbc/jtds-1.3.0.jar /home/john624/workspace/RapidMiner_Unuk/lib/jdbc/mysql-connector-java-5.1.24-bin.jar /home/john624/workspace/RapidMiner_Unuk/lib/jdbc/postgresql-9.2-1002.jdbc4.jar /home/john624/workspace/RapidMiner_Unuk/lib/plugins/rapidminer-Template-${extension.version}.${extension.revision}.${extension.update}.jar [jar] Building jar: /home/john624/workspace/RapidMiner_Unuk/release/rapidminer-Template-${extension.version}.${extension.revision}.${extension.update}.jar [delete] Deleting directory /home/john624/workspace/RapidMiner_Unuk/release/libfiles clean: version.get: [echo] Long version: ${extension.version}.${extension.revision}.${extension.update}; short version: ${extension.version}.${extension.revision} init.setEncoding: init: copy-resources: changes.testExistence: merge.changes: prepare_agpl: build: unzipLibs: [mkdir] Created dir: /home/john624/workspace/RapidMiner_Unuk/release/libfiles [unjar] Expanding: /home/john624/workspace/Paraminer/lib/vldocking.jar into /home/john624/workspace/RapidMiner_Unuk/release/libfiles createJar: install: [move] Moving 1 file to /home/john624/workspace/RapidMiner_Unuk/lib/plugins BUILD SUCCESSFUL Total time: 7 seconds |
Thanks for your help.
