<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.2.000-SNAPSHOT"> <context> <input/> <output/> <macros> <macro> <key>lang</key> <value>en</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="7.2.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.2.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Deals" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="set_macro" compatibility="7.2.000-SNAPSHOT" expanded="true" height="82" name="Set Macro" width="90" x="179" y="34"> <parameter key="macro" value="lang"/> <parameter key="value" value="en"/> </operator> <operator activated="true" class="branch" compatibility="7.2.000-SNAPSHOT" expanded="true" height="103" name="Branch" width="90" x="313" y="34"> <parameter key="condition_type" value="expression"/> <parameter key="expression" value="equals(%{lang}, "en")"/> <process expanded="true"> <connect from_port="input 1" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.2.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Branch" to_port="input 1"/> <connect from_op="Branch" from_port="input 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
