https://username:password@www.example.com/webcallback?foo=bar
is there anything special I need to consider if I'd like to do this with MailChimp?When I try to access MailChimps API I get an error in the brwoser as well as in Rapidminer when using the Base Auth as described here, even as this method is described in the documentation.
The error is:
{"type":"http://developer.mailchimp.com/documentation/mailchimp/guides/error-glossary/","title":"API Key Missing","status":401,"detail":"Your request did not include an API key.","instance":"4646a67f-8cb1-417a-914b-6fabf3539eb3"}
The call I used
https://kll:686XXXXXXXXXXXXXXXXXXXXXXXXXXXXX-us16@us16.api.mailchimp.com/3.0/lists/
But when I use the RESTED extension in Chrome where I can separately enter the user/password credentials it works as expected.
Any hints?
See BUG-Report: https://community.rapidminer.com/t5/RapidMiner-Studio-Forum/BUG-Enrich-Data-by-Webservice-Web-Mining-Does-not-pass-request/td-p/44049/jump-to/first-unread-message
hi @kludikovsky - so this actually works fine. Here's a sample call (API key deleted) with the JSON unparsed:
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="7.6.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="179" y="238"> <list key="attribute_values"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="313" y="238"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="foo" value=".*"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> <parameter key="url" value="https://us7.api.mailchimp.com/schema/3.0/Root.json"/> <list key="request_properties"> <parameter key="content-type" value="application/json"/> <parameter key="Authorization" value="apikey xxxxxxxxxxxxxxx-us7"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Enrich Data by Webservice" to_port="Example Set"/> <connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Scott
Hi @sgenzer,
I can repeat your process, even as there authentication.
I just c did a copy&paste into a new canvas and got a result. So I did no even need a API-key
But the protocol has no sign of the extra data sent:
Paket #3GET /schema/3.0/Root.json HTTP/1.1User-Agent: Java/1.8.0_141Host: us7.api.mailchimp.comAccept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2Connection: keep-alivePaket #4HTTP/1.1 200 OKServer: openrestyContent-Type: application/jsonVary: Accept-EncodingDate: Wed, 29 Nov 2017 16:32:35 GMTContent-Length: 8760Connection: keep-alive{ "$schema": "http://json-schema.org/draft-04/schema#", "type": "object", "title": "API Root", "description": "This resource is nothing more than links to other resources available through the API.", "properties": { "account_id": {
Could you try this please with /lists/.
hello @kludikovsky - yes I see that. I was just accessing the schema. OK please be patient - I will investigate.
OK got it
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="web:get_webpage" compatibility="7.3.000" expanded="true" height="68" name="Get Page" width="90" x="45" y="34"> <parameter key="url" value="https://us7.api.mailchimp.com/3.0/lists"/> <parameter key="user_agent" value="rapidminer"/> <parameter key="accept_cookies" value="all"/> <list key="query_parameters"/> <list key="request_properties"> <parameter key="Authorization" value="apikey xxxxxxxxx-us7"/> </list> <parameter key="override_encoding" value="true"/> <parameter key="encoding" value="UTF-8"/> </operator> <connect from_op="Get Page" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
@sgenzer confirm that it works with the "Get Page".
There are the request information included as can be seen in the trace:
GET /3.0/lists HTTP/1.1User-Agent: rapidminerAuthorization: apikey 68xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx-us16Host: us16.api.mailchimp.comAccept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2Connection: keep-aliveCookie: _AVESTA_ENVIRONMENT=prodPaket #9HTTP/1.1 200 OKServer: openrestyContent-Type: application/json; charset=utf-8Vary: Accept-EncodingX-Request-Id: 3f6c979e-f8f4-412a-bea0-8562753f2d06Link: <https://us16.api.mailchimp.com/schema/3.0/Lists/Collection.json>; rel="describedBy"Content-Length: 17816Date: Wed, 29 Nov 2017 17:27:20 GMTConnection: keep-aliveSet-Cookie: _AVESTA_ENVIRONMENT=prod; path=/{"lists":[{"id":"5c771cab77","web_id":107653,"name":
While the same with "Enrich Data by Webservice" don't supply the information:
GET /3.0/lists/ HTTP/1.1User-Agent: Java/1.8.0_141Host: us16.api.mailchimp.comAccept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2Connection: keep-alivePaket #23HTTP/1.1 401 UnauthorizedServer: openrestyContent-Type: application/problem+json; charset=utf-8Content-Length: 229X-Request-Id: 24037518-be5a-4db7-8c7b-38c33c63e998Link: <https://us16.api.mailchimp.com/schema/3.0/ProblemDetailDocument.json>; rel="describedBy"Date: Wed, 29 Nov 2017 17:37:00 GMTConnection: keep-aliveSet-Cookie: _AVESTA_ENVIRONMENT=prod; path=/{"type":"http://developer.mailchimp.com/documentation/mailchimp/guides/error-glossary/","title":"API Key Missing","status":401,"detail":"Your request did not include an API key.","instance":"24037518-be5a-4db7-8c7b-38c33c63e998"}
So this would conclude that the request properties are not passed on. Which possibly explains some other malfunction I have read on the web.
Thxs Scott.
yes exactly. Unfortunately the "Enrich Data via Webservice" has a lot of trouble with authentication - it's rather out-of-date at this point. I am finding that I see more success with "Get Page", and if that does not work, then "Execute Program" with some cURL statements or calling a shell script.
FWIW you may see a new extension dedicated completely to consuming the most popular APIs natively in RapidMiner (like we do already for Twitter) sometime in the future...
