<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.001" expanded="true" height="68" name="Load Transactions" width="90" x="112" y="187"> <parameter key="repository_entry" value="//Local Repository/data/t123_transactions"/> </operator> <operator activated="true" class="generate_attributes" compatibility="7.0.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="136"> <list key="function_descriptions"> <parameter key="Orders" value="1"/> </list> </operator> <operator activated="true" class="rename" compatibility="7.0.001" expanded="true" height="82" name="Rename" width="90" x="447" y="136"> <parameter key="old_name" value="rechnung"/> <parameter key="new_name" value="Invoice"/> <list key="rename_additional_attributes"> <parameter key="artikel" value="product 1"/> </list> </operator> <operator activated="true" class="aggregate" compatibility="6.0.006" expanded="true" height="82" name="Aggregate" width="90" x="112" y="336"> <list key="aggregation_attributes"> <parameter key="Orders" value="sum"/> </list> <parameter key="group_by_attributes" value="Invoice|product 1"/> </operator> <operator activated="true" class="pivot" compatibility="7.0.001" expanded="true" height="82" name="Pivot" width="90" x="246" y="336"> <parameter key="group_attribute" value="Invoice"/> <parameter key="index_attribute" value="product 1"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="7.0.001" expanded="true" height="82" name="Rename by Replacing" width="90" x="380" y="336"> <parameter key="attribute" value="Invoice"/> <parameter key="replace_what" value="sum\(Orders\)_"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="7.0.001" expanded="true" height="103" name="Replace Missing Values" width="90" x="112" y="442"> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="6.0.003" expanded="true" height="82" name="Numerical to Binominal" width="90" x="246" y="442"/> <operator activated="true" class="set_role" compatibility="7.0.001" expanded="true" height="82" name="Set Role" width="90" x="380" y="442"> <parameter key="attribute_name" value="Invoice"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="store" compatibility="7.0.001" expanded="true" height="68" name="Store" width="90" x="514" y="748"> <parameter key="repository_entry" value="//Local Repository/data/t123_bimominal-transactions_2015"/> </operator> <operator activated="true" class="fp_growth" compatibility="7.0.001" expanded="true" height="82" name="FP-Growth" width="90" x="648" y="289"> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="positive_value" value="true"/> <parameter key="min_support" value="0.005"/> </operator> <operator activated="true" class="create_association_rules" compatibility="7.0.001" expanded="true" height="82" name="Create Association Rules" width="90" x="648" y="442"> <parameter key="min_confidence" value="0.1"/> </operator> <connect from_op="Load Transactions" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_op="FP-Growth" to_port="example set"/> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/> <connect from_op="Create Association Rules" from_port="item sets" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="147"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="42"/> <description align="left" color="yellow" colored="false" height="70" resized="false" width="850" x="20" y="25">MARKET BASKET ANALYSIS<br>Model associations between products by determining sets of items frequently purchased together and building association rules to derive recommendations.</description> <description align="left" color="blue" colored="true" height="185" resized="true" width="550" x="20" y="105">Step 1:<br/>Load transaction data containing a transaction id, a product id and a quantifier. The data denotes how many times a certain product has been purchased as part of a transactions.</description> <description align="left" color="purple" colored="true" height="341" resized="true" width="549" x="20" y="300"><br> <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> Step 2:<br>Edit, transform &amp; load (ETL) - Aggregate transaction data to account for multiple occurrences of the same product in a transaction. Pivot the data so that each transaction is represented by a row. Transform purchase amounts to binary &quot;product purchased yes/no &quot; indicators.<br></description> <description align="left" color="green" colored="true" height="310" resized="true" width="290" x="580" y="105">Step 3:<br/>Using FP-Growth, determine frequent item sets. A frequent item sets denotes that the items (products) in the set have been purchased together frequently, i.e. in a certain ratio of transactions. This ratio is given by the support of the item set.</description> <description align="left" color="green" colored="true" height="215" resized="true" width="286" x="579" y="425"><br> <br> <br> <br> <br> <br> Step 4:<br/>Create association rules which can be used for product recommendations depending on the confidences of the rules.<br></description> <description align="left" color="yellow" colored="false" height="35" resized="true" width="849" x="20" y="655">Outputs: association rules, frequent item set<br></description> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.001" expanded="true" height="68" name="Load Transactions" width="90" x="112" y="187"> <parameter key="repository_entry" value="//Samples/Templates/Market Basket Analysis/Transactions"/> </operator> <operator activated="true" class="aggregate" compatibility="6.0.006" expanded="true" height="82" name="Aggregate" width="90" x="112" y="336"> <list key="aggregation_attributes"> <parameter key="Orders" value="sum"/> </list> <parameter key="group_by_attributes" value="Invoice|product 1"/> </operator> <operator activated="true" class="pivot" compatibility="7.0.001" expanded="true" height="82" name="Pivot" width="90" x="246" y="336"> <parameter key="group_attribute" value="Invoice"/> <parameter key="index_attribute" value="product 1"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="7.0.001" expanded="true" height="82" name="Rename by Replacing" width="90" x="380" y="336"> <parameter key="attribute" value="Invoice"/> <parameter key="replace_what" value="sum\(Orders\)_"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="7.0.001" expanded="true" height="103" name="Replace Missing Values" width="90" x="112" y="442"> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="6.0.003" expanded="true" height="82" name="Numerical to Binominal" width="90" x="246" y="442"/> <operator activated="true" class="set_role" compatibility="7.0.001" expanded="true" height="82" name="Set Role" width="90" x="380" y="442"> <parameter key="attribute_name" value="Invoice"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" breakpoints="before" class="fp_growth" compatibility="7.0.001" expanded="true" height="82" name="FP-Growth" width="90" x="648" y="289"> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="positive_value" value="true"/> <parameter key="min_support" value="0.005"/> </operator> <operator activated="true" class="create_association_rules" compatibility="7.0.001" expanded="true" height="82" name="Create Association Rules" width="90" x="648" y="442"> <parameter key="min_confidence" value="0.1"/> </operator> <connect from_op="Load Transactions" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="FP-Growth" to_port="example set"/> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/> <connect from_op="Create Association Rules" from_port="item sets" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="147"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="42"/> <description align="left" color="yellow" colored="false" height="70" resized="false" width="850" x="20" y="25">MARKET BASKET ANALYSIS<br>Model associations between products by determining sets of items frequently purchased together and building association rules to derive recommendations.</description> <description align="left" color="blue" colored="true" height="185" resized="true" width="550" x="20" y="105">Step 1:<br/>Load transaction data containing a transaction id, a product id and a quantifier. The data denotes how many times a certain product has been purchased as part of a transactions.</description> <description align="left" color="purple" colored="true" height="341" resized="true" width="549" x="20" y="300"><br> <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> Step 2:<br>Edit, transform &amp; load (ETL) - Aggregate transaction data to account for multiple occurrences of the same product in a transaction. Pivot the data so that each transaction is represented by a row. Transform purchase amounts to binary &quot;product purchased yes/no &quot; indicators.<br></description> <description align="left" color="green" colored="true" height="310" resized="true" width="290" x="580" y="105">Step 3:<br/>Using FP-Growth, determine frequent item sets. A frequent item sets denotes that the items (products) in the set have been purchased together frequently, i.e. in a certain ratio of transactions. This ratio is given by the support of the item set.</description> <description align="left" color="green" colored="true" height="215" resized="true" width="286" x="579" y="425"><br> <br> <br> <br> <br> <br> Step 4:<br/>Create association rules which can be used for product recommendations depending on the confidences of the rules.<br></description> <description align="left" color="yellow" colored="false" height="35" resized="true" width="849" x="20" y="655">Outputs: association rules, frequent item set<br></description> </process> </operator></process>
