<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="dl4j_extension:word_2_vec" compatibility="1.0.000" expanded="true" height="82" name="Word2Vec" width="90" x="45" y="85"> <parameter key="file_path" value="C:\Users\user\.RapidMiner\repositories\Local Repository\data\raw_sentences.txt"/> <enumeration key="stop_words"/> </operator> <operator activated="true" class="set_role" compatibility="7.0.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="85"> <parameter key="attribute_name" value="Word"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="multiply" compatibility="7.0.000" expanded="true" height="103" name="Multiply" width="90" x="313" y="85"/> <operator activated="true" class="agglomerative_clustering" compatibility="7.0.000" expanded="true" height="82" name="Clustering" width="90" x="447" y="85"> <parameter key="mode" value="CompleteLink"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <operator activated="true" class="data_to_similarity_data" compatibility="7.0.000" expanded="true" height="68" name="Data to Similarity Data" width="90" x="447" y="187"> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <connect from_op="Word2Vec" from_port="vector" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Clustering" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Data to Similarity Data" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/> <connect from_op="Clustering" from_port="example set" to_port="result 2"/> <connect from_op="Data to Similarity Data" from_port="similarity example set" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="42"/> <portSpacing port="sink_result 2" spacing="21"/> <portSpacing port="sink_result 3" spacing="42"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
Hi, this seems to be no longer available, any way to still get hold of this?
it's still compilable from GitHub: https://github.com/LostSummer233/rapidminer-extension-dl4j-pack
~Martin
It's been a while since your last post. Is RapidMiner going forward with this extension or dropping it? I'm looking for a recurrent NN plug-in for RM and this seemed to be it. Any other recommendations for RNN & RM?
