<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.000" expanded="true" height="68" name="Retrieve Products" width="90" x="45" y="136"> <parameter key="repository_entry" value="//Samples/data/Products"/> </operator> <operator activated="true" class="select_attributes" compatibility="7.0.000" expanded="true" height="82" name="Select Attributes" width="90" x="112" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Product ID"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="7.0.000" expanded="true" height="82" name="Set Role" width="90" x="313" y="187"> <parameter key="attribute_name" value="Product Name"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="k_means" compatibility="7.0.000" expanded="true" height="82" name="Clustering" width="90" x="447" y="34"> <parameter key="k" value="4"/> </operator> <connect from_op="Retrieve Products" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/> <connect from_op="Clustering" from_port="clustered set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
