<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="6.5.002" expanded="true" height="60" name="Read Excel" width="90" x="112" y="75"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="set_role" compatibility="6.5.002" expanded="true" height="76" name="Set Role" width="90" x="246" y="75"> <parameter key="attribute_name" value="MyFieldName"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="subprocess" compatibility="6.5.002" expanded="true" height="76" name="Subprocess" width="90" x="380" y="165"> <process expanded="true"> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Doing stuff here.</description> </operator> <connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Subprocess" to_port="in 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
