I am new to CFD FEM simulation. Should the residuals in a steady state simulation reach the same order as other CFD SWs (something like 1e-6) or can the default value of 1e-3 be fine? Also is the number of iterations, which defaults to 100, that numbers needs to be higher?
And what trend should the solution ratio have?
Both the residuals and solution ratio graphs have a decreasing trend with only a few spikes at times (but not that high).
I ask these questions because in my simulation I reach these values and the simulation stops after 20-30 iterations, and I have some doubt about the convergence (I checked the results with another SW and they are almost the same, the results change by something like 1-5%).
Thanks in advance
