Hello everyone,
I'm pretty new to Rapidminer and Data Mining in general and wanted to try to cluster a collection of color images by color. After some time experimenting with rapidminer I managed to create a somewhat correct looking process, but I still get unidentified errors.
Below is the xml of my process.Note that this process is atm just clustering by general image features, not color in particular. Basically what I tried is loading images from multiple sources using the MCIO operator. As a subprocess of this, I use local feature extraction with POIs generated from an integral image source.
The resulting exampleset is then used for clustering by SVM.
Where did I go wrong with this process? Would you mind pointing out my mistakes and propose a possible solution?
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.4.001" expanded="true" height="60" name="MCIO" width="90" x="45" y="30">
<list key="images">
<parameter key="birne" value="C:\Users\nick\Pictures\fruitveggiecollection\JPG\AbateFetelPear"/>
<parameter key="acorn" value="C:\Users\nick\Pictures\fruitveggiecollection\JPG\Acorn"/>
<parameter key="almond" value="C:\Users\nick\Pictures\fruitveggiecollection\JPG\Almond"/>
</list>
<parameter key="assign_label" value="true"/>
<operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Multiply" width="90" x="45" y="30"/>
<operator activated="true" class="imageprocessing:color_to_grayscale" compatibility="1.4.001" expanded="true" height="60" name="Color to grayscale (3)" width="90" x="179" y="120"/>
<operator activated="true" class="imageprocessing:integral_image" compatibility="1.4.001" expanded="true" height="60" name="Integral Image" width="90" x="313" y="120"/>
<operator activated="true" class="imageprocessing:interest_poin_detector" compatibility="1.4.001" expanded="true" height="60" name="interest_poin_detector" width="90" x="447" y="120">
<parameter key="point_count" value="800"/>
<operator activated="true" class="imageprocessing:feature_extraction_operator2" compatibility="1.4.001" expanded="true" height="94" name="Local Feature Extractor with Points" width="90" x="581" y="30">
<operator activated="true" class="imageprocessing:color_to_grayscale" compatibility="1.4.001" expanded="true" height="60" name="Color to grayscale (4)" width="90" x="45" y="30"/>
<operator activated="true" class="imageprocessing:contrast_of_gray_level_values" compatibility="1.4.001" expanded="true" height="60" name="contrast_of_gray_level_values" width="90" x="179" y="30"/>
<connect from_port="image 1" to_op="Color to grayscale (4)" to_port="color image plus"/>
<connect from_op="Color to grayscale (4)" from_port="grayscale image" to_op="contrast_of_gray_level_values" to_port="grayscale image plus"/>
<connect from_op="contrast_of_gray_level_values" from_port="feature" to_port="feature 1"/>
<portSpacing port="source_image 1" spacing="0"/>
<portSpacing port="source_image 2" spacing="0"/>
<portSpacing port="sink_feature 1" spacing="0"/>
<portSpacing port="sink_feature 2" spacing="0"/>
</process>
<connect from_port="color image plus" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Local Feature Extractor with Points" to_port="color image plus"/>
<connect from_op="Multiply" from_port="output 2" to_op="Color to grayscale (3)" to_port="color image plus"/>
<connect from_op="Color to grayscale (3)" from_port="grayscale image" to_op="Integral Image" to_port="grayscale image plus"/>
<connect from_op="Integral Image" from_port="integral image" to_op="interest_poin_detector" to_port="Integral Image"/>
<connect from_op="interest_poin_detector" from_port="Points" to_op="Local Feature Extractor with Points" to_port="points"/>
<connect from_op="Local Feature Extractor with Points" from_port="example set" to_port="Example set"/>
<portSpacing port="source_color image plus" spacing="0"/>
<portSpacing port="sink_Example set" spacing="0"/>
</process>
<operator activated="true" class="support_vector_clustering" compatibility="5.3.013" expanded="true" height="76" name="Clustering (2)" width="90" x="246" y="30"/>
<connect from_op="MCIO" from_port="example set" to_op="Clustering (2)" to_port="example set"/>
<connect from_op="Clustering (2)" from_port="cluster model" to_port="result 1"/>
</process>
</process>
