<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.012"> <context> <input/> <output/> <macros> <macro> <key>mparam</key> <value>"1"</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="5.3.012" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="web:get_webpage" compatibility="5.3.001" expanded="true" height="60" name="Get Page" width="90" x="45" y="165"> <parameter key="url" value="http://www.econ.yale.edu/~shiller/data/ie_data.xls"/> <list key="query_parameters"/> <list key="request_properties"/> <parameter key="encoding" value="windows-1250"/> </operator> <operator activated="false" class="loop_parameters" compatibility="5.3.012" expanded="true" height="76" name="Loop Parameters" width="90" x="45" y="300"> <list key="parameters"> <parameter key="Write Document.encoding" value="ISO-8859-1,ISO-8859-13,ISO-8859-15,ISO-8859-2,ISO-8859-3,ISO-8859-4,ISO-8859-5,ISO-8859-6,ISO-8859-7,ISO-8859-8,ISO-8859-9,JIS_X0201,JIS_X0212-1990,KOI8-R,KOI8-U,Shift_JIS,TIS-620,US-ASCII,UTF-16,UTF-16BE,UTF-16LE,UTF-32,UTF-32BE,UTF-32LE,UTF-8,windows-1250,windows-1251,windows-1252,windows-1253,windows-1254,windows-1255,windows-1256,windows-1257,windows-1258,windows-31j,x-Big5-HKSCS-2001,x-Big5-Solaris,x-euc-jp-linux,x-EUC-TW,x-eucJP-Open,x-IBM1006,x-IBM1025,x-IBM1046,x-IBM1097,x-IBM1098,x-IBM1112,x-IBM1122,x-IBM1123,x-IBM1124,x-IBM1364,x-IBM1381,x-IBM1383,x-IBM33722,x-IBM737,x-IBM833,x-IBM834,x-IBM856,x-IBM874,x-IBM875,x-IBM921,x-IBM922,x-IBM930,x-IBM933,x-IBM935,x-IBM937,x-IBM939,x-IBM942,x-IBM942C,x-IBM943,x-IBM943C,x-IBM948,x-IBM949,x-IBM949C,x-IBM950,x-IBM964,x-IBM970,x-ISCII91,x-ISO-2022-CN-CNS,x-ISO-2022-CN-GB,x-iso-8859-11,x-JIS0208,x-JISAutoDetect,x-Johab,x-MacArabic,x-MacCentralEurope,x-MacCroatian,x-MacCyrillic,x-MacDingbat,x-MacGreek,x-MacHebrew,x-MacIceland,x-MacRoman,x-MacRomania,x-MacSymbol,x-MacThai,x-MacTurkish,x-MacUkraine,x-MS932_0213,x-MS950-HKSCS,x-MS950-HKSCS-XP,x-mswin-936,x-PCK,x-SJIS_0213,x-UTF-16LE-BOM,X-UTF-32BE-BOM,X-UTF-32LE-BOM,x-windows-50220,x-windows-50221,x-windows-874,x-windows-949,x-windows-950,x-windows-iso2022jp"/> </list> <process expanded="true"> <operator activated="true" class="text:write_document" compatibility="5.3.001" expanded="true" height="76" name="Write Document" width="90" x="45" y="210"> <parameter key="file" value="C:\Users\john.heath\Desktop\TestDataRM\ie_data.xls"/> <parameter key="encoding" value="x-JISAutoDetect"/> </operator> <operator activated="true" class="log" compatibility="5.3.012" expanded="true" height="76" name="Log" width="90" x="112" y="120"> <list key="log"> <parameter key="lparameter" value="operator.Write Document.parameter.encoding"/> </list> </operator> <operator activated="true" class="log_to_data" compatibility="5.3.012" expanded="true" height="94" name="Log to Data" width="90" x="179" y="30"/> <operator activated="true" class="extract_macro" compatibility="5.3.012" expanded="true" height="60" name="Extract Macro" width="90" x="313" y="30"> <parameter key="macro" value="mparam"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="lparameter"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="handle_exception" compatibility="5.3.012" expanded="true" height="76" name="Handle Exception" width="90" x="246" y="255"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="5.3.012" expanded="true" height="60" name="Read Excel (3)" width="90" x="45" y="75"> <parameter key="sheet_number" value="3"/> <parameter key="imported_cell_range" value="A1:L2423"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Comment"/> <parameter key="1" value="Comment"/> <parameter key="2" value="Comment"/> <parameter key="3" value="Comment"/> <parameter key="4" value="Comment"/> <parameter key="5" value="Comment"/> <parameter key="6" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Date.true.real.attribute"/> <parameter key="1" value="P.true.real.attribute"/> <parameter key="2" value="D.true.real.attribute"/> <parameter key="3" value="E.true.real.attribute"/> <parameter key="4" value="CPI.true.real.attribute"/> <parameter key="5" value="Fraction.true.real.attribute"/> <parameter key="6" value="Rate GS10.true.real.attribute"/> <parameter key="7" value="Price.true.real.attribute"/> <parameter key="8" value="Dividend.true.real.attribute"/> <parameter key="9" value="Earnings.true.real.attribute"/> <parameter key="10" value="CAPE.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="store" compatibility="5.3.012" expanded="true" height="60" name="Store" width="90" x="179" y="120"> <parameter key="repository_entry" value="//Local Repository/data/AllExcel/%{mparam}"/> </operator> <connect from_port="in 1" to_op="Read Excel (3)" to_port="file"/> <connect from_op="Read Excel (3)" from_port="output" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="file" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Extract Macro" to_port="example set"/> <connect from_op="Log to Data" from_port="through 1" to_op="Handle Exception" to_port="in 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="text:write_document" compatibility="5.3.001" expanded="true" height="76" name="Write Document (2)" width="90" x="179" y="210"> <parameter key="file" value="C:\Users\john.heath\Desktop\TestDataRM\ie_data.xls"/> <parameter key="encoding" value="ISO-8859-1"/> </operator> <operator activated="true" class="read_excel" compatibility="5.3.012" expanded="true" height="60" name="Read Excel (2)" width="90" x="313" y="255"> <parameter key="sheet_number" value="3"/> <parameter key="imported_cell_range" value="A1:L2423"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Comment"/> <parameter key="1" value="Comment"/> <parameter key="2" value="Comment"/> <parameter key="3" value="Comment"/> <parameter key="4" value="Comment"/> <parameter key="5" value="Comment"/> <parameter key="6" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Date.true.real.attribute"/> <parameter key="1" value="P.true.real.attribute"/> <parameter key="2" value="D.true.real.attribute"/> <parameter key="3" value="E.true.real.attribute"/> <parameter key="4" value="CPI.true.real.attribute"/> <parameter key="5" value="Fraction.true.real.attribute"/> <parameter key="6" value="Rate GS10.true.real.attribute"/> <parameter key="7" value="Price.true.real.attribute"/> <parameter key="8" value="Dividend.true.real.attribute"/> <parameter key="9" value="Earnings.true.real.attribute"/> <parameter key="10" value="CAPE.true.polynominal.attribute"/> </list> </operator> <connect from_op="Get Page" from_port="output" to_op="Write Document (2)" to_port="document"/> <connect from_op="Write Document (2)" from_port="file" to_op="Read Excel (2)" to_port="file"/> <connect from_op="Read Excel (2)" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros> <macro> <key>mparam</key> <value>"1"</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel_format" compatibility="5.3.013" expanded="true" height="60" name="Read Excel with Format" width="90" x="179" y="30"/> <connect from_port="input 1" to_op="Read Excel with Format" to_port="file"/> <connect from_op="Read Excel with Format" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?php $target_url = 'http://192.168.0.30:8090/RA/public_process/PostXLSWS'; $revisionFile = realpath('test.xls'); $postData = array( 'revision' => '@'.$revisionFile, ); $response = sendPost($target_url, $postData); echo "<p><b>Response Code:</b></p>"; echo "<p>" . $response['code'] . "</p>"; echo "<p><b>Response Content:</b></p>"; echo "<div style=\"border: solid 1px red; min-width: 100px; min-height: 100px; padding: 10px;\">"; echo "<p>" . $response['content'] . "</p>"; echo "</div>"; echo "<p><a href=\"\">REFRESH</a></p>"; function sendPost($address, $data) { $ch = curl_init(); curl_setopt($ch, CURLOPT_URL, $address); curl_setopt($ch, CURLOPT_POST, 1); curl_setopt($ch, CURLOPT_POSTFIELDS, $data); curl_setopt($ch, CURLOPT_RETURNTRANSFER, true); $responseContent = curl_exec($ch); $responseCode = curl_getinfo($ch, CURLINFO_HTTP_CODE); $response = array(); $response['content'] = $responseContent; $response['code'] = $responseCode; curl_close($ch); return $response; }?>
