I'm writing my own QuickFix in MetaDataError class. The code looks like this:
public class BadColorMetaDataError extends ImageMetaDataError {
private boolean color = true;
public BadColorMetaDataError(InputPort inputPort, String message, boolean color) {
super(Severity.ERROR, inputPort, message);
this.color = color;
@Override
public List<? extends QuickFix> getQuickFixes() {
List<QuickFix> list = Collections.<QuickFix>emptyList();
if(color){
list.add(new OperatorInsertionQuickFix("insert_gs_to_color", new Object[0], 10, (InputPort)getPort()) {
@Override
public Operator createOperator() throws OperatorCreationException {
Operator op = OperatorService.createOperator(GrayScaleToColorOp.class);
return op;
} else {
list.add(new OperatorInsertionQuickFix("insert_color_to_gs", new Object[0], 10, (InputPort)getPort()) {
@Override
Operator op = OperatorService.createOperator(ColorToGrayScaleOp.class);
return op;
return list;
My ErrorsImage.properties file defined in build.xml by
<property name="extension.errorDescription" value="/com/rapidminer/resources/i18n/ErrorsImage.properties" />
looks like this:
metadata.quickfix.insert_color_to_gs = Insert Color to Grayscale operator.
metadata.quickfix.insert_gs_to_color = Insert Grayscale to Color operator.
When I run RapidMiner, I get this error:
Exception in thread "AWT-EventQueue-0" java.lang.UnsupportedOperationException
at java.util.AbstractList.add(AbstractList.java:148)
at java.util.AbstractList.add(AbstractList.java:108)
at com.burgsys.image.core.ioobjects.metadata.errors.BadColorMetaDataError.getQuickFixes(BadColorMetaDataError.java:28)
at com.rapidminer.gui.flow.ErrorTable$4.getValueAt(ErrorTable.java:249)
at com.rapidminer.gui.tools.ExtendedJTableSorterModel.getValueAt(ExtendedJTableSorterModel.java:328)
at javax.swing.JTable.getValueAt(JTable.java:2716)
at javax.swing.JTable.prepareRenderer(JTable.java:5714)
at javax.swing.plaf.basic.BasicTableUI.paintCell(BasicTableUI.java:2114)
at javax.swing.plaf.basic.BasicTableUI.paintCells(BasicTableUI.java:2016)
at javax.swing.plaf.basic.BasicTableUI.paint(BasicTableUI.java:1812)
at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
at javax.swing.JComponent.paintComponent(JComponent.java:778)
at javax.swing.JComponent.paint(JComponent.java:1054)
at javax.swing.JComponent.paintChildren(JComponent.java:887)
at javax.swing.JComponent.paint(JComponent.java:1063)
at javax.swing.JViewport.paint(JViewport.java:731)
at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1047)
at com.vlsolutions.swing.docking.SplitContainer.paint(SplitContainer.java:192)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5221)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1512)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1443)
at javax.swing.RepaintManager.paint(RepaintManager.java:1236)
at javax.swing.JComponent._paintImmediately(JComponent.java:5169)
at javax.swing.JComponent.paintImmediately(JComponent.java:4980)
at javax.swing.RepaintManager$3.run(RepaintManager.java:796)
at javax.swing.RepaintManager$3.run(RepaintManager.java:784)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:784)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:757)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:706)
at javax.swing.RepaintManager.access$1000(RepaintManager.java:62)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1651)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:727)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:688)
at java.awt.EventQueue$3.run(EventQueue.java:686)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:697)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
And I really don't know where should I look for problem. Can somebody point me where to start.
Thanks for your responses.
Best,
Vaclav
