<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="string" value=""string1string2string3""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="string" value=""string1string4string3""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="255"> <list key="attribute_values"> <parameter key="string" value=""string2""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.008" expanded="true" height="112" name="Append" width="90" x="246" y="75"/> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="75"> <list key="function_descriptions"> <parameter key="match" value="matches(string,".*string2.*")"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.008" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="75"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="match=true"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="648" y="75"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|match"/> <parameter key="invert_selection" value="true"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
CharlieFirpo wrote:In SQL, I can use a query like this: SELECT * FROM <table name> WHERE <column name> LIKE '%<specific string>%'
Retegniw wrote:Once you have set up a database connection (Tools > Manage Database Connections) you can use the "Read Database" operator and its query property to write an SQL query. Roland
