[SOLVED] using the text extension as an dependency
User: "RaedMarji"
New Altair Community Member
Updated by Jocelyn
Dear All,
Im tryiing to implement a new operator that relies on the Text Processing extension Classes like Document and Token, so I was wondering what is the appropriate way to do this? I would prefer if you can explain this in regards of both the build.xml file and my build path.
Thanks In Advance. ;)
1 - 3 of 31
    User: "Nils_Woehler"
    your build.dependentExtensions tag should look like this
    <fileset id="build.dependentExtensions" dir="..">
    <include name="RapidMiner_Plugin_TextProcessing_Unuk/build.xml" />
    </fileset>
    Furthermore you should add the extension dependency:
    <property name="extension.dependencies" value="rmx_text[5.3]" />
    And for your project configuration you should add the dependency to the
    text processing extension of course :-)
    Best regards,
    Nils
    User: "RaedMarji"
    OP
    thanks Nils, that helped but regarding my scnd question I think it wasnt clear, for now I havent been able to to this without adding the text ext jar so is it the right way?
    User: "Marco_Boeck"
    regarding your build path it really does not matter much, you can either add the .jar or checkout the project sources via SourceForge and add the whole project as a dependency.
    Marco
