hi , I'm doing the sentiment analysis using rapidMiner 5 , I build a process and I want to see results in eclips , I follow the documentation , and I connected eclipse with rapidMiner , I create a new class and I add the RapidMiner-unk project and I put those line of code
package rm.com;
import com.rapidminer.RapidMiner;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.operator.ExecutionMode;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.IOObject;
import com.rapidminer.repository.IOObjectEntry;
import com.rapidminer.repository.ProcessEntry;
import com.rapidminer.repository.RepositoryLocation;
import java.lang.String;
import com.rapidminer.Process;
public class rm {
     public static void main(String args[]) throws Exception {
    // this initializes RapidMiner with your repositories available
    	 RapidMiner.setExecutionMode(com.rapidminer.RapidMiner.ExecutionMode.COMMAND_LINE);
    RapidMiner.init();
    // loads the process from the repository
    RepositoryLocation pLoc = new RepositoryLocation("//C:/Users/fujitsu/.RapidMiner5/repositories/Local Repository/exple1");
    ProcessEntry pEntry = (ProcessEntry) pLoc.locateEntry();
    String processXML = pEntry.retrieveXML();
    Process myProcess = new Process(processXML);
    // if need be, you can give the process IOObjects as parameter (this would be the case if you used the process input ports)
    RepositoryLocation loc = new RepositoryLocation("//C:/Users/faith/Desktop/MyRepository/MyData/cars");
    IOObjectEntry entry = (IOObjectEntry) loc.locateEntry();
    IOObject myIOObject= entry.retrieveData(null);
    // execute the process and get the resulting objects
    IOContainer ioInput = new IOContainer(new IOObject[] {myIOObject});
    // just use myProcess.run() if you don't use the input ports for your process
    IOContainer ioResult = myProcess.run(ioInput);
    // use the result(s) as needed, for example if your process just returns one ExampleSet, use this:
    if (ioResult.getElementAt(0) instanceof ExampleSet) {
        ExampleSet resultSet = (ExampleSet)ioResult.getElementAt(0);
but these errores occure when I start runnig
24 mars 2013 16:48:05 com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
24 mars 2013 16:48:05 com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
24 mars 2013 16:48:05 com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying base directory of classes (build) 'C:\workspace\rapidMiner'...gotcha!
24 mars 2013 16:48:08 com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Text Processing
INFO: Register plugin: Weka
INFO: Register plugin: Web Mining
24 mars 2013 16:48:26 com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of Expression parser registered successfully
24 mars 2013 16:48:29 com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
24 mars 2013 16:48:44 com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 518; number of registered operator descriptions: 644; number of replacements: 441
24 mars 2013 16:48:45 com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
24 mars 2013 16:48:45 com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
[Fatal Error] :1:1: Premature end of file.
Exception in thread "main" com.rapidminer.repository.RepositoryException: Requested repository C: does not exist.
	at com.rapidminer.repository.RepositoryManager.getRepository(RepositoryManager.java:200)
	at com.rapidminer.repository.RepositoryLocation.getRepository(RepositoryLocation.java:139)
	at com.rapidminer.repository.RepositoryLocation.locateEntry(RepositoryLocation.java:162)
	at rm.com.rm.main(rm.java:21)
the results that I get from rapidMiner
on eclipe I just want to get the content of the metadata file and the prediction label , can anyone help me , thanks
NB : I run the new project and the rapidminer-unuk using jre7 , does that cause problem ?
