So, for reasons that can only be described as silly, I'm unable to use svn to load my project into Eclipse. Instead I went to the SourceForge page and downloaded the file "rapidminer-5.3.005.zip" opened up the project and imported it into Eclipse as a pre-existing project.
Everything seems to show up fine, but I'm having trouble getting Eclipse to execute RapidMinerGUI. I've set up a new Debug Configuration with the following info:
Project: RapidMiner_Unuk
Main Class: com.rapidminer.gui.RapidMinerGUI
Includes system library's when searching for a main class: yes
Include inherited mains when searching for a main class: yes
Stop in main: No
When I tell it to debug I get this error:
java.lang.NoClassDefFoundError: com/rapidminer/gui/RapidMinerGUI
Caused by: java.lang.ClassNotFoundException: com.rapidminer.gui.RapidMinerGUI
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
For some reason it can't seem to see the RapidMinerGUI inside of the provided class file. This is especially odd to me because I used a wizard to find the class...so it seems like if the wizard can see it, Eclipse should be able to as well.
Any thoughts?
