"Problems with building an Extension"
I'm a student and my latest task is to build a new extension for RapidMiner implementing some of my profesors methods.
I've have been carefully following all the instructions I could find online, but I've reached a problem I can't solve. When I try to run createjar from build.xml of RapidMiner_Extension_Template I get following output:
- my RapidMiner resources are up to date (checked out today)
- I'm using java 1.7
- I changed Vega to Unuk in build.xml
- I added <exclude name="**/*" /> to build.xml
Is there anything I missed? I will be happy for any help you can provide me.
Thank you,
Milan
I have read some topics about it here and checked all the answers to this topis i could find:
Buildfile: C:\Users\vizour\workspace\RapidMiner_Extension_Template\build.xml
clean:
[echo] Cleaning...
[delete] Deleting directory C:\Users\vizour\workspace\RapidMiner_Extension_Template\build
[delete] Deleting directory C:\Users\vizour\workspace\RapidMiner_Extension_Template\javadoc
[mkdir] Created dir: C:\Users\vizour\workspace\RapidMiner_Extension_Template\build
[mkdir] Created dir: C:\Users\vizour\workspace\RapidMiner_Extension_Template\javadoc
version.get:
[echo] Long version: ${extension.version}.${extension.revision}.${extension.update}; short version: ${extension.version}.${extension.revision}
init.setEncoding:
init:
Trying to override old definition of task get
Trying to override old definition of task rpm
Trying to override old definition of task post
init.setEncoding:
copy-resources:
[echo] Copying resources...
[copy] Copying 9 files to C:\Users\vizour\workspace\RapidMiner_Extension_Template\build
changes.testExistence:
merge.changes:
build:
build.rm:
version.get:
[echo] Long version: 5.3.000; short version: 5.3
init:
Trying to override old definition of task downloadOperatorDocumentation
Trying to override old definition of task head
Trying to override old definition of task put
copy-resources:
version.updateFiles:
[echo] Updating to version 5.3.000
check.newDocumentationPresent:
create-documentation:
merge.changes:
[echo] Merging all changes files
build:
[echo] RapidMiner: Compile with Java from dir: C:\eclipse\jre
[echo] RapidMiner: using Java version: 1.7.0_09
[javac] Compiling 12 source files to C:\Users\vizour\workspace\RapidMiner_Unuk\build
BUILD FAILED
C:\Users\vizour\workspace\RapidMiner_Unuk\build_extension.xml:139: The following error occurred while executing this line:
C:\Users\vizour\workspace\RapidMiner_Unuk\build_extension.xml:204: The following error occurred while executing this line:
C:\Users\vizour\workspace\RapidMiner_Unuk\build.xml:174: Error running javac.exe compiler
Total time: 3 seconds
Thank you,
Milan
1 - 3 of
31
Hello Nils,
thank you for your answer. Unfortunately even this build.xml file produced the "same" output:
Thank you
Do you have any idea why it does that?
Trying to override old definition of task javac
clean:
[echo] Cleaning...
version.get:
init.setEncoding:
init:
[taskdef] Could not load definitions from resource antlib.xml. It could not be found.
[taskdef] Could not load definitions from resource org/freecompany/redline/ant/antlib.xml. It could not be found.
[copy] Warning: Could not find file C:\Users\vizour\workspace\RapidMiner_Extension_Template\ant\jsch-0.1.42.jar to copy.
init.setEncoding:
copy-resources:
merge.changes:
build:
build.rm:
version.get:
init:
copy-resources:
merge.changes:
build:
BUILD FAILED
Total time: 10 seconds
clean:
[echo] Cleaning...
version.get:
init.setEncoding:
init:
init.setEncoding:
copy-resources:
merge.changes:
build:
build.rm:
version.get:
init:
copy-resources:
merge.changes:
build:
BUILD FAILED
Thank you
if your build.xml still referenced RapidMiner_Vega, than it definitly is not up to date.
Try using this one: Best,
Nils
