Hi All,
I am running Rapidminer in Ubuntu Linux 12.10 and my java version is 7 update 11.
I have tried to export some results through the upper button in the right corner (the logo is a HD with a green arrow) but the dialog that comes up does not allow to select the type of file, (
the drop down button is empty). Besides, the browse button does not work and pressing the OK button yields an error dialog box:
"Error writing image file" . The description of the error is the following:
java.lang.NullPointerException
at org.freehep.util.export.ExportDialog.writeFile(ExportDialog.java:217)
at org.freehep.util.export.ExportDialog.setValue(ExportDialog.java:228)
at javax.swing.plaf.basic.BasicOptionPaneUI$ButtonActionListener.actionPerformed(BasicOptionPaneUI.java:1198)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:682)
at java.awt.EventQueue$3.run(EventQueue.java:680)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:696)
at java.awt.EventQueue$4.run(EventQueue.java:694)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:693)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219)
at java.awt.Dialog.show(Dialog.java:1077)
at java.awt.Component.show(Component.java:1651)
at java.awt.Component.setVisible(Component.java:1603)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1003)
at org.freehep.util.export.ExportDialog.showExportDialog(ExportDialog.java:181)
at com.rapidminer.gui.actions.ExportViewAction.actionPerformed(ExportViewAction.java:54)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Find attached some screen captures too:
I could not reproduce the same error using Rapidminer in Windows, however all linux versions I have used yield the same error pressing the same button.
Thank you in advance for your responses,
Richard
